20 Most Recent
Marvin 1210 Floor / Box Fan Questions & Answers
Marvin Model 1220. I have
I own a Marvin model 1220 box fan since 10 years ago. The stand broke on the hooks part. I need the buy the same, please help me on this. It is out of stock in the Internet. This fan is fantastic, but need to keep it clean so the blades don't slow down do to dust
Fan has stopped working
The deep cleaning is required initially, then also check if the motor is jammed up or weak.you can test the voltage on the motor with a meter.
If the motor coil is weak or faulty, replace it .if it is just jammed up.then get the motor internally serviced.
This a very common problem and the solution as i said above will solve the issue .
Thanks. keep updated for any more query.you can rate this solution
and show your appreciation.
I have a Marvin 1210 window fan with a rotating front grill
mcdevito75 here, hello ken, I did a fast search and I think www. shop.com can help you out with Marvin air fans, I didn"t find anything on Marvin Air Fans itself. Now about the nose cone covering the nut holding the blade to the fan shaft, most of these nose covers are press fit, see if you can gently pry that nose cover off with a small screwdriver.
Marvin Box Fan Cleaning
It has six phillips-head screws around the perimeter. Loosen all six screws and the halves separate. Be careful loosening the screw that holds the motor in place - I ended up stripping the head. If you can use a vice grip to get it started, that may help.
Fan blades
their is problem in push! change your fan push! then the wings are rotate
