20 Most Recent
Olympus DSS Player 7 Questions & Answers
I have installed the DSS
1st does the software specifically say it will work on your particular MAC operating system? This is important.
Can't get the footswitch RS-26
If you have version 6 installed.
Download version 7 and all its updates which is a free upgrade then simply goto help and updates
do the updates for version 7 and hey presto the foot pedal will work.
I have DS-3000 player but
You will need to get the disk to install on your system, otherwise, you can not play/create any sound file as said, i will advice you get a copy from any of your friend that uses it and install on your mac Book pro, you can also check there web site to see if you can download a copy, with that, i believe the problem should fix.
Take care.
The computer recognises my Olympys digital voice
Have you try to reinstall the software, many times thoose software are much complicated and comes with strange errors. Try to : uninstall the software, reboot the computer, and reinstall the software and try again.
Hope that helps
IF NOT then return here :O)
Have a nice day
Please rate my answer
Olympus DSS Pro Player Transcription software - Need to find serial
El n?mero de serie del software Olympus DSS Player Pro se almacena en el propio software. Puede encontrarlo seleccionando Ayuda, luego Acerca del m?dulo de dictado o Acerca del m?dulo de transcripci?n. Adem?s, el n?mero de serie tambi?n se puede encontrar en el propio CD, en una hoja cuadrada de papel verde del tama?o de una cubierta de CD. El n?mero de serie tambi?n se almacenar? en el registro de la computadora, pero esto no deber?a ser necesario para la instalaci?n.
1/6/2023 2:58:25 AM •
Olympus...
Answered
on Jan 06, 2023
Olympus VN3100PC not accesible anymore
Please ensure that the hold switch is NOT in the hold position because this disables all of your operations. The hold switch is on the left side of your device above the usb port.
Also, if this does not work, please test your batteries on another working device to ensure that they still have power.
Thank you.
10/25/2022 8:32:57 PM •
Olympus...
Answered
on Oct 25, 2022
L'objectif de mon Olympus Stylus 710 ne reste pas ouvert, je ne peux pas prendre de photos ,que faire?
The lens of my Olympus Stylus 710 does not stay open, I can not take pictures, what to do
https://translate.google.com/#auto/en/L'objectif%20de%20mon%20Olympus%20Stylus%20710%20ne%20reste%20pas%20ouvert%2C%20je%20ne%20peux%20pas%20prendre%20de%20photos%20%2Cque%20faire
http://www.fixya.com/support/t195207-olympus_stylus_710_problem_lens
IF YOU PRESS AND HOLD THE ok/function BUTTON, AND TURN THE CAMERA ON AND OFF A FEW TIMES WHILST KEEPING THIS BUTTON DEPRESSED, IT SHOULD HOPEFULLY SORT ITSELF OUT?!
(NOT SURE IF IT MAKES A DIFFERENCE BUT MY DIAL WAS SET TO scn FOUND INBETWEEN guide & the wobbly hand.
I ONLY TURNED on/off/on AND IT FIXED THE ERROR, IT MAY TAKE MORE FOR YOU.....I'M NOT SURE AS MINE IS NOW FIXED!
IT WORKED FOR ME, HOPE THIS HELPS, GOOD LUCK!
Mike
Posted on Jan 22, 2008
SI VOUS APPUYEZ ET MAINTENEZ LE BOUTON OK / DE FONCTION, ET METTEZ L'APPAREIL EN MARCHE ET A L'ARRET QUELQUES FOIS, TOUT EN MAINTENANT QUE CE BOUTON EST DEPRIM?, IL DEVRAIT S'ATTENDRE EXPRESSEMENT?
(PAS S?R SI CELA FAIT UNE DIFF?RENCE MAIS MON CADRAN A ?T? R?GL? POUR RETROUVER LE GUIDE INBETWEEN ET LA MAIN BRUYANTE.
Je n'ai allum? que ON / OFF / ON ET IL FIXE L'ERREUR, IL PEUT PRENDRE PLUS POUR VOUS ..... JE NE SUIS PAS S?R COMME LA MINE EST MAINTENANT FIXE!
Il a travaill? pour moi, j'esp?re que cela aide, bonne chance!
Mike
Publi? le 22 janv. 2008
http://translate.google.com/
5/16/2018 11:49:00 PM •
Olympus...
Answered
on May 16, 2018
