20 Most Recent
G7 Productivity Systems VersaCheck Home & Business 2002 (GVC/111084) for PC Questions & Answers
WHATS THE VALIDATION KEY FOR VERSACHECK X1 GT PLATINUM
They are different for each purchaser. You get one with the purchase. If you got this from someone else or a copy from someone, then either they must give you their key, or you'll need to buy the program outright to get one. Otherwise, you are in violation of the EULA. We don't give out hack keys here, as we are not a hacker site.
I got a new computer
Browse the installation disc and navigate to the "setup.exe" file. Once you've located this file, right click on it and then click on "Properties". On the window that appears, select the "Compatibility" tab and, under "Compatibility mode", check the "Run this program in compatibility mode for:" check-box and select from the list below the check-box "Windows XP (Service Pack 3)" and then click on "OK".
It will now install and run properly.
I need to print business
hi
i'm not sure this will help you or not try following link you will find solution
http://www.business-checks.net/?brand=G7+Productivity+Systems_504390
I am unable to install
1. Check that the path exists, i.e., you have a folder named: C:\Program Files\G7PS\VersaCheck 2002\_Update\
2. Check that you have permissions to create a file there, e.g., create a simple dummy.txt file in this directory with notepad (you can delete the test file after that)
If (1) is the problem - create the necessary folder(s)
if (2) is the problem - check the you run as administrator
