20 Most Recent
Dell UltraSharp 2208WFP 22" Widescreen LCD Monitor Questions & Answers
Dell 2208wfpt settings for portrait rotation?
Andrew Scharlach,
Are you changing the rotation using the ctrl+alt+right arrow. left arrow or down arrow? That is how i change the rotation on the screen. If needed lower the resolution in the display settings in control panel.
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Dell 2208WFPt no power - nothing.
Check the cord at the wall and the back of the monitor. If you can use a known-good cord, and still nothing, then your best bet is replacing the monitor completely.
2208wfpt
The problem is caused by one or more capacitors that have opened in the power supply/inverter board, sometimes they show a bulge at the top making it easier to spot.
2208wfpt flickering, not staying on
The problem is in the power supply/inverter board, there are more than likely one or more bad capacitors that open, "sometimes bulges at top" the other concern is one of the inverter transformers may be bad, or a failing backlight behind the display.
If you add a DVI adapter to the the DVI cable
For the best results, you a straight DVI cable.
VGA is analog, while DVI is digital. The quality will not be as good a a regular DVI cable.
You can use a DVI to HDMI.
I use one going from my PC to TV and the quality is awesome.
I connect an external hard
Will any USB device (keyboard, mouse, memory-stick) work when connected to your Dell monitor?
Will those USB devices (including your external disk-drive) work when _directly_ connected to your computer?
DELL 2208WFP LCD-Comes on normally, but almost
I believe the power led button is still on while the
screen goes dark, if yes, it means the picture board of your monitor is
bad that is why it appears for a second and goes dark after that
Since
the power led button is on, It means the picture
board on your monitor is faulty that is why it appears for a second and
goes dark.
The best thing for you to do now is to take the
monitor to
a local repairer or any service center within your vicinity to help
with the replacement of the picture board because the fault is not
something you can fix yourself in other to complicate issues.
Take care.
