20 Most Recent Hyundai Electronics E465D 46 in. LCD TV Questions & Answers
Blue picture
It is your "vergin media box" outputting a blue screen!
When this TV has no input it displays a msg box "No Input Signal" or "Signal out of Range" (PC video resolution is not correct.)
10/22/2009 11:29:03 PM • Hyundai... • Answered on Oct 22, 2009
My hyundai tv has a perodic vertical black line
1st resolder inverter board, if the problem still exist chek the flex cable.
9/11/2014 7:30:41 AM • Hyundai... • Answered on Sep 11, 2014
0answers
0answers
0answers
3answers
Hello. First, thanks in
Hi.
It is not a lose wire. If problem was a lose wire or a bad solder joint it would have been sensible to vibration and the TV would have turned off when touched.
It is not a software problem either. The software cannot turn off the TV completely, at most the TV would freeze or go in standby.
If TV goes off completely, the problem is usually a defective PSU in rare situations a defective inverted can also give similar problems.
The problem is usually the PSU, A component (usually a capacitor starts failing) The other capacitors in PSU can compensate the work that is not being done by the defective part, and the PSU works for a while, until problem starts happening more often and TV does not turn on at all. In some case a defective inverter can do the same. In that case the inverter oscillator section is defective. The problem with the inverter is very uncommon.
Check the power supply. Sometimes it is possible to see at a glance a burnt spot or capacitors bulged on top. If there is nothing at a glance the PSU should be tested before replacing it.
PSU part number is PSCV121106B the PSU is not available anymore, the repair must be done replacing the parts on PSU. Below the repair kit with the components. For safety reasons the repair must be done by a trained person.
Here the repair kit: Repair Kit PSU PSCV1211068
Regards.
Ginko
5/30/2011 9:35:28 AM • Hyundai... • Answered on May 30, 2011
0answers
32" TFT LCD TV remote
You can get a 'Universal' remote from most electrical stores. You will need to get a set up code for your TV - try this site http://www.xdiv.com/remotes/
2/18/2011 7:58:07 PM • Hyundai... • Answered on Feb 18, 2011
I need service mode procedure for hyundai
by replacing the memory . thanks anyway.
6/11/2009 3:02:28 PM • Hyundai... • Answered on Jun 11, 2009
Harwa Smart television. How to restore Apps, it doesn't want to open for Apps.
Check the internet connection. The television can't update if it can't see the internet. Resetting it breaks the previous settings. Just for fun, reboot the router as well and wait 15 minutes until all the lights come back on. Then reestablish the television connection to the router. Harwa is not a make we know here in North America. https://www.google.com/search?q=Harwa+Smart+television.+How+to+restore+Apps ..
4/25/2024 3:46:43 PM • Televison &... • Answered 9 hours ago
2answers
My television will suddenly turn off every 4 minutes or so and when I turn it back on it will do it again. I need help to stop this please?
The most obvious reason is an overheating issue in the Power Supply board. There are other ideas here, but you need to take it to a television engineer to diagnose https://www.google.com/search?q=television+will+suddenly+turn+off+every+4+minutes ..
4/25/2024 3:46:35 PM • Televison &... • Answered 9 hours ago
How to remove child lock from BELTEK TV?
general steps: Get the TV remote control and push the "Menu" button and select "Options". Select "Child Lock" from the "Options" list. On some televisions, the "Child Lock" is named "V-chip". Choose the "Remove Child Lock" selection. Highlight this and then hit the "Enter" button. Enter the four-digit code that you used when you activated the child lock feature. If you cannot remember it, your only option to deactivate the child lock is to reset the TV. The instructions for resetting a TV is written on the user's manual of the TV. Exit the TV menu once you have entered the four-digit code. To do this, press the "Exit" or "Menu" button on the TV's remote control. If you don't have a remote, you might try leaving the TV unplugged overnight. Some TVs will 'forget' their settings if left without power for a long period. You could also potentially buy a cheaper universal remote, and use that to turn off the child lock.
4/22/2024 8:10:04 PM • Televison &... • Answered 3 days ago
How to pairing Ruwido Amadeus R 9710 to tv?
To pair your Ruwido Amadeus R 9710 remote to your TV, you can follow these steps: Insert Batteries: Your remote is powered by two 1.5 V AAA batteries1. Make sure to insert the batteries correctly. Switch on your TV: Ensure your TV is turned on. Press the TV key: Press the TV key on your remote control for approximately 4 seconds until the LED flashes twice. Enter the Code: After seeing the 2 flashes and within 5 seconds, enter the 3-digit numerical code from the list provided with your remote2. After entering the code, the LED will flash twice indicating that the code has been accepted. Test the Remote: Point the remote control towards your TV and press the key. If your TV does not respond by going into Stand-By mode then repeat steps 3 to 5 and enter the next code in the list. Bed.-Anl. H2 Version1 (ruwido.com)
4/21/2024 7:58:23 PM • Televison &... • Answered on Apr 21, 2024
My ecco TV is on but the screen is black when flashing light I can see the picture tv model LH 32.
That sounds like it has a backlight fault. A good TV engineer can possibly repair that for you.
4/21/2024 2:31:53 PM • Televison &... • Answered on Apr 21, 2024
Tek L26D10. How to open the unlock the TV unlock code for Tek model L26D10?
Ask your parents. There is no easy way to defeat the parental lock.. https://www.google.com/search?q=Tek+model+L26D10+TV+unlock+code ..
4/21/2024 5:35:32 AM • Televison &... • Answered on Apr 21, 2024
6answers
Vistron remote codes for sky
TV maker is Palladium codes are 0560, 398, 391, 446
4/20/2024 8:49:55 PM • Televison &... • Answered on Apr 20, 2024
JVC KW-AV50 DVD receiver. None of the volume Up or Down buttons work JVC KW-AV50.
Try cleaning behind them with electronics switch cleaner spray, but it may be the whole module is faulty. https://www.google.com/search?q=jvc+kw+av50+volume+button+not+working ..
4/20/2024 6:31:28 PM • Televison &... • Answered on Apr 20, 2024
Hyundai Electronics E465D 46 in. LCD TV Logo
1 questions posted
Top Hyundai Electronics Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
Are you a Hyundai Electronics Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Hyundai Electronics Televison & Video
Most Popular Question
blue picture
  • Televison & Video
