20 Most Recent MagLite Mag Lite® 2x 'd' Battery Flashlight In Display Box Black Case Questions & Answers
Won't light with new batteries and bulb
look where the batteries go and make sure there is no crud or corrosion in the housing or on the spring in the end cap .if you remove the bulb and check the voltage using a multimeter ,if its under 3 volts you have a bad connection somewhere in the housing.
11/17/2012 3:27:35 PM • MagLite Mag... • Answered on Nov 17, 2012
I could not unscrew the
Counter clockwise to get bottom cap off. They're usually pretty tight because cap is steel and tube is aluminum. Grab tube with pliers and try turning cap
7/14/2011 8:39:40 AM • MagLite Mag... • Answered on Jul 14, 2011
2answers
Batteries are stuck in the flashlight. How do I
If they are stuck, they have probably leaked and the flashlight is probably corroded already. But here are two suggestions. Get a heavy piece of string and tie it securely around the flashlight at the lens end. Tape it on with duct tape for good measure. When hung by the string the lens end of the flashlight should point up and the open end should point down. Stand in a place with lots of space and no windows or pets or people around. Swing the string over your head to generate some g's. The batteries may come flying out. Another suggestion is to drill a hole in the battery, put a long screw in it and pull it out. Wear safety goggles. If the second battery is also stuck you will need a long drill and a longer screw. Good luck.
2/24/2011 6:05:13 AM • MagLite Mag... • Answered on Feb 24, 2011
How to battties in a mag light.
The bottom unscrews.When you get the bottom open,screw the top(where the lightbulb is) down further.Hold the flaslight almost sideways and slide the batteries in,then turn the flashlight back up so as not to let the batteries slam.The little positive nipple goes in first for both batteries.After you screw in the bottom,then you can adjust the top end for proper usage/operation.Greg
12/18/2010 5:32:33 PM • MagLite Mag... • Answered on Dec 18, 2010
New batteries, bulb looks fine, no light-what
hold the glass part of the bulb, and twist the metal base. there may be a break there. good luck, hope this helps.
11/6/2010 7:15:16 PM • MagLite Mag... • Answered on Nov 06, 2010
I can twist the head of my Mini Maglite to turn it on and off but I can't unscrew it completely to replace the lamp. It tightens up like it has run out of threads.
Stand it lens down and squirt WD40 down the gap and leave it standing overnight. That is the way the head comes off. My guess is that it is binding on the o-ring.
2/8/2021 12:52:34 AM • MagLite Camping,... • Answered on Feb 08, 2021
Repair site for 5 cell maglite
It would be best if you visit the official of Maglite. It has all the required information which will solve your queries. The site has all the categories like spare parts etc.
9/21/2020 2:17:18 PM • MagLite Camping,... • Answered on Sep 21, 2020
How to remove led bulb from my maglite led this one doesnt just slide out after unscrewing cover
This is the easiest answer I have found to date . Go to ; http://maglite.com/ and click " Support " . Follow the links from there ! Good luck . Alec .
2/7/2018 6:33:13 PM • MagLite Camping,... • Answered on Feb 07, 2018
On the xL50 Maglite how to remove the top part
Hello, you can find some video on youtube. https://www.youtube.com/watch?v=G8wmQKgOk7U Just type maglite dissasembly.
9/18/2017 8:29:53 PM • MagLite Camping,... • Answered on Sep 18, 2017
Maglite 3-d batteries will not unscrew battery access cap. even used rubber for grip and use of channel lock pliers. all aluminum model.what else can I do to remove cap to access bat.
I'm gonna catch it for this but this is how I did it. Corroded batteries in the cylinder will eat and seize the aluminum threads on the end cap and it's pretty much toast after that. What I did was drill, yes drill a 0.125" (1/8") hole exactly .25" (1/4") above the seam between the end cap and the tube .0125" (1/8") into the tube. No more than that or you will jeopardize the integrity of the waterproof factor. Drop one drop of a quality penetrating oil, or even diesel fuel, into the hole every hour while randomly tapping the tube with a metal object to create a vibration to help the penetrating oil travel throughout the threads and dislodge the corrosive hold on your end cap. It might take a couple of days to loosen it up and try it with your channel-locks and a lined vice or strong wife. Just plan on gaining 1/32" movement and go back and forth until it gives up the grip. That process might take another day too. Keep adding the drop of penetrating oil along with the tapping religiously. It WILL work provided your patience holds out. Don't force it... well, not too much anyway. You can actually save it this way.
12/21/2016 3:20:35 AM • MagLite Camping,... • Answered on Dec 21, 2016
3answers
Corroded batteries stuck in a mini AA maglite
yes the bulb assy can be removed as it's basically the switch you need like a special tool for removing it. but first which brand of battery is in it. both energizer and Duracell have warranty about replacing item that the battery has damaged. try that route is my suggestion before trying to remove batteries and possibly breaking the switch. you can get one sent to you by calling up customer service as i replaced one before mini mag lite also.
8/25/2015 12:40:29 PM • MagLite Camping,... • Answered on Aug 25, 2015
0answers
MagLite Mag Lite® 2x 'd' Battery  Flashlight In Display Box Black Case Logo
6 questions posted
Top MagLite Camping, Backpacking & Hiking Experts
ADMIN Andrew
ADMIN Andrew
Kardoc
Are you a MagLite Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
View Most Popular
  • MagLite Camping, Backpacking & Hiking
Most Popular Question
could not unscrew
  • Camping, Backpacking & Hiking
