20 Most Recent
Deadbolt Bioaxxis Bd1 Biometric Fingerprint Door Lock Questions & Answers
Installed bioaxxis bd1 deadbolt, when batteries
This is a link to the installation manual. If your results vary from the expected, contact Axxis Biometrics support for assistance:http://www.axxisbiometrics.com/images/upload/File/pdfs/BD1HS_Complete_User_Manual.pdfhttp://www.axxisbiometrics.com/support/A note about PDF files: If you cannot view a given file, you need to first install Adobe Reader. You can get the free download here:http://get.adobe.com/reader/Good luck!
11/28/2012 8:27:15 PM •
Deadbolt...
Answered
on Nov 28, 2012
Hi I just installed my
Here is a link to the user manual:http://www.axxisbiometrics.com/images/upload/File/pdfs/BD1_Complete_User_Manual.pdfA note about PDF files: If you cannot view a given file, you need to first install Adobe Reader. You can get the free download here:http://get.adobe.com/reader/If you still have questions, contact Axxis Biometrics from this link:http://www.axxisbiometrics.com/products/locks/deadbolt-fingerprint/bioaxxis-bd1/Good luck!
11/9/2011 4:26:38 PM •
Deadbolt...
Answered
on Nov 09, 2011
My door lock will not
Here is the contact number that you need:
877-299-4701
AXXIS Biometrics does not provide an on-line manual, so calling them is your only recourse.
Good luck--and please provide feedback if this helps!
9/6/2011 10:24:52 PM •
Deadbolt...
Answered
on Sep 06, 2011
The lock will not lock
877-299-4701
9/6/2011 10:24:34 PM •
Deadbolt...
Answered
on Sep 06, 2011
My bioaxxis bd1 finger print
Here is the link to the website for the manufacturer, Axxis Biometrics:
I want you to have that because if all else fails, you'll have the contact information for further assistance.
Here is the direct link to the installation and programming instructions, which includes the beep codes. You likely lost the programming when you left the batteries out for such a long period:
Notice that the above is a .pdf filetype. That means that you need to have Adobe Reader or similar installed on your computer to view it. So if you are unable to view the file, download (for free) and install Adobe Reader first. You can get it here:
Hope this helps. Good luck!
8/8/2011 10:16:43 PM •
Deadbolt...
Answered
on Aug 08, 2011
The alarm is setting off
I downloaded the PDF file for this lock to find out about the beeps. I
had to use Internet Explorer; Firefox wouldn't work. This is what I
found:
Single, Short Beep - Indicates that any operations sequence has
begun OR that the door has been successfully locked or unlocked
OR that the sliding cover has been left open for more than ten
seconds.
Single, Long Beep - Indicates that programming operation was
successful
Short, Double Beep - Indicates that individual fingerprint user
deletion sequence has begun.
Long Double Beep - Indicates that Delete All programming was
successful
Four Beeps - Indicates unsuccessful enrollment/unsuccessful
verification attempt OR BioAxxis® BD1 was improperly installed
(see Installation Guide).
Six, Short Beeps - Low battery alert, change batteries
The link to download this file is here:
This is a PFD file, requiring that you have Adobe Reader installed on your computer to view it.
This is a link to AxxisBiometrics webpage, which has a toll-free help number blasted across it, if all else fails:
For a $250 lock, if you the beep codes I supplied you doesn't answer
your question, I wouldn't hesitate to call them up. Good luck! (duplicated to clear both requests for help)
7/26/2011 10:15:15 PM •
Deadbolt...
Answered
on Jul 26, 2011
The lock is sounding off
I downloaded the PDF file for this lock to find out about the beeps. I had to use Internet Explorer; Firefox wouldn't work. This is what I found:
seconds.
successful
successful
For a $250 lock, if you the beep codes I supplied you doesn't answer your question, I wouldn't hesitate to call them up. Good luck!
7/26/2011 10:14:26 PM •
Deadbolt...
Answered
on Jul 26, 2011
Lock Wont Program, Tried to reset and delete all
Hello. SInce this is brand new, return it. If someone else already used it; their data will not be penetratable without you sending it into the company for a factory reset, along with proof of purchase and two forms of ID. Joe
I had this exact same problem a while ago.
10/24/2010 3:42:08 PM •
Deadbolt...
Answered
on Oct 24, 2010
Resetting Master pin on rona Electronic Deadbolt lock
GoogleRona Electronic Deadbolt Lock Instructions:Default Master Code:123Resetting Master PIN:Remove batteries and put them back. You will hear a long beep and a short beep.Press and hold the 0 button until you hear 3 long beeps and the LED flashes red for 3 seconds. You are now in program mode.Within 10 seconds, key in a new master PIN (up to 12 digits) and press the UNLOCK button.Key in the master PIN again and press the UNLOCK button. The LED will flash green for 1 second and the resetting is complete.Adding a PIN:Key in master PIN and press UNLOCK buttonPress and hold 0 button until you hear 2 short beeps and the LED flashes for 3 seconds.Release 0 button and you are in the Add PIN modeWithin 10 seconds, enter a new PIN and press the UNLOCK button. You will hear one beep.Key in the new PIN again and press the UNLOCK button twice. When the LED stops flashing the PIN has been added.make model resetting lock
https://www.google.com/search?q=resetting+Master+pin+on+rona+Electronic+Deadbolt+lock..
I had to replace my batteries in my electronic deadbolt and now it won't let me reset the code and I've followed the directions and not working
You didn't say what brand or model, so here's a generic answer:
Find the instructions to reset it to factory codes. Sometimes this is as easy as removing the battery and waiting an hour (or a day) and other times you have to enter special codes, or disconnect a jumper, or connect 2 points with a wire to erase the codes. Once you have the lock reset, put brand new batteries in and follow the instructions for programming a brand new lock.
If you don't have the instructions, you can often find them online by entering the brand and model # into the search box of Google or YouTube along with a word or phrase like "instructions" or "manual" or "getting started."
