20 Most Recent
Dayton Universal Ac/Dc Open Motor 1 Hp 10,000 Rpm 115V Rotation 2M191 Questions & Answers
ITEM: Dayton universal motor
My engineering experience tells me that this is likely caused by sudden acceleration or deceleration of the motor. Not knowing the type of load the motor is driving I can only point you to look for things causing sudden load changes. I would be tempted to install a soft start circuit or inrush current limiter that accelerates the motor slower or possibly install a flywheel to reduce acceleration/deceleration torque pulses. As a final suggestion, I would present the problem to the manufacturer of the appliance and the motor.
How much should good scaffold brick guards cost me?
These should be expensive, but they are nothing of the sort. You can pick up quality scaffold brick guards online for as little as £3.99. I use a company called
BrikGard because they use 100% recycled plastic scaffold brick guards. I like to be as environmentally friendly as possible without compromising quality or increasing the purchase cost too much. Given that their brick guards are so cheap and made from 100% recycled plastic, I feel safe using them. Also, anyone working on-site should consider using a brick guard because it offers that extra layer of peace of mind so you can get focused on the job without worrying about things like falling debris coming down and striking you. For affordable scaffold brick guards, I would check out BrikGard.
