20 Most Recent Bemis 7MCLRDRCT NA Elongated Toilet Seat 7MCLRDRCT Questions & Answers
What toilet seat hinge replaces
The hinges and bumpers on plastic seats are not replaceable. The bumpers are molded in and the hinges are installed with special tools while the plastic is still warm.
Sorry but that's way Bemis does things and is way most good Plumbing shops will not buy or sell them.
They were not like that untill they started having their seats made in China however this may help you http://www.bing.com/shopping/search?q=bemis+toilet+seat+replacement+parts&FORM=HURE
http://www.bizrate.com/plumbing-supplies/oid1620858646.html
4/4/2011 8:40:39 PM • Bemis 7MCLRDRCT... • Answered on Apr 04, 2011
Removing rusted nuts from bolts to replace toilet seat
Try:
* Penetrating oil...let it soak at least 1/2 hour
* If the nut is stripped, try either grabbing it with vice grips
* If all else fails, either grind it off, or use a nut splitter. Nylon is pretty soft, so it should be relatively easy to break
4/28/2009 1:27:31 PM • Bemis 7MCLRDRCT... • Answered on Apr 28, 2009
Can I replace Bemis 1500EC toilet seat hinges w/Slow-Close hinges?
Here it is again; https://www.choicereplacementtoiletseatshop.co.uk/c/spare-parts/toilet-seat-hinges
6/15/2022 6:10:16 PM • Bemis Home • Answered on Jun 15, 2022
2answers
Is there a site to buy Whisper Close or Soft Close 'hinges only' for a Bemis Whisper Close elongated toilet seat.
6/15/2022 6:08:51 PM • Bemis Home • Answered on Jun 15, 2022
Our Bemis toilet is clogged, how do we unclog it?
6 Ways to Unclog your toliet 1. Baking Soda 2. Vinegar 3. Auger 4. Dawn Dish Soap 5. Hot Water 6. Plunger if first 5 don't work
4/3/2022 4:01:31 PM • Bemis Home • Answered on Apr 03, 2022
Easy Clean Commode Seat. Why can't I lift it off even after I unlock the top hinges?
The commode seat is bolted in place. The top "hinges" you are unlocking are merely decorative covers for the retaining bolts.
1/16/2021 5:48:45 PM • Bemis Home • Answered on Jan 16, 2021
How to fix a Bemis Easy Clean Soft Close Toilet seat?
ONLY FIX I AM AWARE OF IS TO REPLACE IT
11/30/2020 4:39:16 PM • Bemis Home • Answered on Nov 30, 2020
I can't figure out how to remove the old Bemis toilet seat to replace it. The wingnut doesn't turn there's only one wing?
most newer plastic seat cover nuts are only one wing --use pliers or hand to remove
4/30/2020 2:54:58 AM • Bemis Home • Answered on Apr 30, 2020
How do I remove a bemis whisper close seat with sta-tite?
It is just whithin your mind
1/15/2019 12:27:18 AM • Bemis Home • Answered on Jan 15, 2019
Bemis whisper close toilet seat stopped being quiet, lid slams
This is probably a friction hinge. The slow closing feature is a result of friction within the hinge. So it sounds like the hinge has worn to the point of the friction being reduced. Another possibility is that some kind of lubricating fluid entered the hinge. If so, perhaps it will regain friction with time. Most likely the seat needs to be replaced.
9/2/2017 9:23:46 PM • Bemis Home • Answered on Sep 02, 2017
0answers
How do we unclog a bemis toilet?
use a product that has sodium hypochlorite ( caustic soda ) as the active ingredient ( draino , mr muscle or what ever you have from your hard ware shop) this product reacts with organic materials and breaks them down very quickly use eye protection and gloves as the product is extremely corrosive follow the instructions on the container if the system is septic , find another product that will not kill the bacteria in the tank
10/25/2016 6:07:19 AM • Bemis Home • Answered on Oct 25, 2016
T am trying to remove a Bemis sattite toilet seat. How do I do it?
if you cannot get it to unseat you can take a hacksaw and carefully cut the bolts from under seat on top of toilet base easiest way to remove seat
10/2/2015 1:58:39 AM • Bemis Home • Answered on Oct 02, 2015
Bemis 7MCLRDRCT NA Elongated Toilet Seat 7MCLRDRCT Logo
4 questions posted
Top Bemis Home Experts
john h
ADMIN Andrew
ADMIN Andrew
Steve Pack
Steve Pack
Are you a Bemis Home Expert? Answer questions, earn points and help others
View Most Popular
Bemis Home
  • Bemis Home
Most Popular Question
  • Home
