20 Most Recent Psi Spray Flex Pressure Washer Gun Attachment 3000 Questions & Answers
I have a 1700 PSI Greenworks pressure washer it leaks only when I hit the hit the one what is the problem
Hi, that selection must cause too much internal pressure for certain parts of your device to handle so the leak occur to ....let off a little pressure. Please work with Greenworks to find out whether you need to replace a part of your device to overcome the leak. Their number is 1-888-909-6757. Thank you.
10/19/2022 8:43:56 PM • Psi Garden • Answered on Oct 19, 2022
42A.707 1653.01 17hp twin ohv new everything won't start
A flooded engine will not start even with starter fluid.
You need to get the cylinders dried out and try starter fluid alone by draining the fuel from the carburetor bowl and pinch off the fuel line at the carb inlet. Then remove spark plugs and crank engine for several seconds to dry out the cylinders.
Next, reinstall spark plugs and remove the air filter. Leave fuel line pinched off. Set 3/4 throttle (choke off). Then spray a 1 second burst of starter fluid directly into the carburetor throat. Don't bother with the air filter and promptly start the engine.
8/3/2022 3:58:42 PM • Psi Garden • Answered on Aug 03, 2022
I have a 3100 psi power washer what kind of oil do I need
Impossible to answer definitively without maker and model, but this says SAE 10W-30. That is a powerful industrial machine! https://www.google.com/search?q=3100+psi+power+washer+what+kind+of+oil& ..
6/16/2022 6:23:54 PM • Psi Garden • Answered on Jun 16, 2022
2answers
How can I get an instruction manual for a hyper tough 1800 psi electric power washer
Several sold in the last two years are not available now. Might be able to offer to purchase a copy of the manual only from a seller of the the power washer. https://www.granstore.xyz/pressure-washers-c-1_2_970_978/hyper-tough-1800-psi-electric-pressure-washer-model-5100219-new-p-6931.htm?language=en
6/5/2022 3:29:15 PM • Psi Garden • Answered on Jun 05, 2022
My brand new pressure washer is smoking
if properly assembled and properly used then return it for another or refund
11/8/2021 12:22:27 PM • Psi Garden • Answered on Nov 08, 2021
How do I print the manual for the Manual for workforce 2500 psi 163cc pressure washer
with a printer ...first you have to find the manual. try google
5/7/2021 7:40:17 PM • Psi Garden • Answered on May 07, 2021
The 1700 psi pressure was sputters after about 30 seconds and stoops.
really? Bleed the water line b4 you start.
9/5/2019 3:00:04 PM • Psi Garden • Answered on Sep 05, 2019
What is the compression on a wed eater blower vac i have 90 psi is that enough 25cc its a 1650 model
90 psi is sufficient for combustion.
4/18/2019 2:31:51 AM • Psi Garden • Answered on Apr 18, 2019
Husky 2600 psi pressure washer starts then shuts off immediately
Try holding the wand while squeezing the trigger, or have an assistant do that. Then try and start it. It sounds like the trapped line pressure is too much for a cold engine. If it starts in this fashion you'll be all set.
If it does the same thing with less load on it, you could have 2 other possible issues. If this unit has a low oil shutdown switch, it will act the way you are describing also. Check the oil level. The other possible cause could be some blockage in the fuel line, or gunk on the needle and seat in the carb from bad fuel or sitting a long time and varnishing up.
9/29/2018 2:52:20 PM • Psi Garden • Answered on Sep 29, 2018
My generac 2700 psi pressure washer problem. When I try to pull the starter cord, it will not pull. What could be the issue?
sounds like the motor is frozen, if a gasoline motor sits for a long time without use rust can freeze it up. Also if something inside has broken it can freeze the motor. If it was running when you last put it away probably rusted inside. Also the pull cord starting mechanism can lock up, if you can remove it and turn the motor by hand then it is the pull cord mechanism.
3/12/2018 5:58:45 PM • Psi Garden • Answered on Mar 12, 2018
2answers
I have a Black Max 2600 PSI pressure washer, model BM80913, that gives a surge of pressure, and then pressure drops off. Solution?
Pump needs to be rebuilt or replaced, some of those pumps have a replacement surge valve inside, some do not If you need further help, I’m available over the phone at https://www.6ya.com/expert/michael_2094e122cc46f24c
9/27/2017 6:39:05 PM • Psi Garden • Answered on Sep 27, 2017
WHAT TYPE OF OIL TO USE ON POWERMATE MONSOON 1600 PSI POWER WASHER?
in the engine --normal 15w-30 engine oil
8/2/2017 10:24:56 AM • Psi Garden • Answered on Aug 02, 2017
How do i change the oil on a king craft 2200 psi pressure washer
Best way to do it is to suck it out with one of those pumps designed to suck engine oil out of a car engine. Or you can try to siphon it out.
6/13/2017 1:26:56 AM • Psi Garden • Answered on Jun 13, 2017
What size capacitor does my 120volt Landa pressure washer take? The model# zf2-1000d. Serial# p0803-62727. PSI 1000.
Sorry we do not have that information.
5/11/2017 10:40:55 PM • Psi Garden • Answered on May 11, 2017
Greenworks 1700 psi starts ok, but cuts off after about 5-10 minutes. After waiting a few minutes, it will run again.
Check and see if it losses ignition spark when it stalls, if it does the ignition pickup may be defective.
4/15/2017 9:05:09 PM • Psi Garden • Answered on Apr 15, 2017
Psi Spray Flex Pressure Washer Gun Attachment 3000 Logo
Popular Tags
0 questions posted
Top Psi Garden Experts
Jay Finke
Jay Finke
MrFixitSTTL
ADMIN Andrew
ADMIN Andrew
Are you a Psi Garden Expert? Answer questions, earn points and help others
View Most Popular
Psi Garden
  • Psi Garden
Most Popular Question
compression wed eater blower vac 90 psi
  • Garden
