20 Most Recent
Psi 3000 Pressure Washer Hose Questions & Answers
42A.707 1653.01 17hp twin ohv new everything won't start
A flooded engine will not start even with starter fluid.
You need to get the cylinders dried out and try starter fluid alone by draining the fuel from the carburetor bowl and pinch off the fuel line at the carb inlet. Then remove spark plugs and crank engine for several seconds to dry out the cylinders.
Next, reinstall spark plugs and remove the air filter. Leave fuel line pinched off. Set 3/4 throttle (choke off). Then spray a 1 second burst of starter fluid directly into the carburetor throat. Don't bother with the air filter and promptly start the engine.
8/3/2022 3:58:42 PM •
Psi Garden
Answered
on Aug 03, 2022
Husky 2600 psi pressure washer starts then shuts off immediately
Try holding the wand while squeezing the trigger, or have an assistant do that. Then try and start it. It sounds like the trapped line pressure is too much for a cold engine. If it starts in this fashion you'll be all set.
If it does the same thing with less load on it, you could have 2 other possible issues. If this unit has a low oil shutdown switch, it will act the way you are describing also. Check the oil level. The other possible cause could be some blockage in the fuel line, or gunk on the needle and seat in the carb from bad fuel or sitting a long time and varnishing up.
9/29/2018 2:52:20 PM •
Psi Garden
Answered
on Sep 29, 2018
