20 Most Recent
RTO Paslode #650027 2500CT Placement Nail Questions & Answers
How to clean a paslode nail gun
which one?? or you can try and go to Paslode.com with your model number and see if you can download a breakdown for this tool along with cleaning instructions.
My paslode nail gun needs to be cleaned
Use the Paslode cleaning spray (Lowes and home depot stock this)
Detailed instructions can be downloaded from the paslode site. http://www.paslode.com/owners-manuals.html
How do i clean my paslode
Here is a tip that I wrote
about the Paslode nailers and the problems that can come up
with them.
I also have a link to the Paslode manuals
which contain Paslode cleaning and troubleshooting guides.
If
you need parts for your Paslode, there also is a link for a
site that sells the Paslode nailer parts.
Paslode
Cordless Nailer Problems
heatman101
I have a paslode airless
Hello harderconstr, I have that nail gun myself, and when it's working good it is a great tool to have.
Here are a few suggestions.
1. Remove the battery, make sure that you don't have a nail jammed in the the firing chamber, that has happened to mine before.
2. Adjust the depth tension on the end of the gun. You should have an alen wrench to loosen the adjuster at the tip. Slide the adjuster away from the gun, ( out ) as far as it will go and then tighten it back down. Reinstall the battery and try it again. You can re-adjust the tension after you see if this helps the problem. The adjuster on my gun was worn and I needed to adjust the tension to get it firing again.
3. I also got a new battery for my gun, and what I found was I really had to slide the battery in pretty hard to get it to click in place. Also, when you hold the gun in your right hand, the thumb side of the handle should have a very small LED light, red means it's not ready to fire, green means it is ready to fire. Make sure you have a green light.
I hope this helps you my friend!
Paslode air framer not sinking some nails
Your air pressure is dropping everytime you fire. It sound like your compressor is not cutting back in untill it to low. Not giving your tool enough continuess pressure. Your compressor cut in pressure should be around 90-100psi no less. and your max. pressure no more then 120psi. (Make sure your regulator is set at 110psi)
good luck...!
How much should good scaffold brick guards cost me?
These should be expensive, but they are nothing of the sort. You can pick up quality scaffold brick guards online for as little as £3.99. I use a company called
BrikGard because they use 100% recycled plastic scaffold brick guards. I like to be as environmentally friendly as possible without compromising quality or increasing the purchase cost too much. Given that their brick guards are so cheap and made from 100% recycled plastic, I feel safe using them. Also, anyone working on-site should consider using a brick guard because it offers that extra layer of peace of mind so you can get focused on the job without worrying about things like falling debris coming down and striking you. For affordable scaffold brick guards, I would check out BrikGard.
Removal Storage
If you are looking for a company who use latest equipments then i would refer you to appoint "bison removals" or "guildford removals". These two companies have excellent instruments to make your removal effortless.
