20 Most Recent Stanley 46 - 071 Contractor Grade Quick Square Layout Tool Questions & Answers
I don't know what all
I answer questions for free.
I used a framing square for every day for years and frankly I never knew all the lines either.
At fixya they say 'real' experts don't provide a link but instead explain every detail to answer the question.
However in this case, the best detail is the following:
Do a google search for 'how to use a framing square.'
http://www.carpentry-pro-framer.com/framing-square.html
After reading about the framing square, if you have a specific question how to use it, then add a comment and I will help fill out the details. For example if the terminology is confusing.
Here's my favorite framing square tip:
Put the square on the edge of a piece of plywood.
Hold the pencil at a mark.
Then slide the square along the plywood while holding the pencil, and it makes a long straight line. It takes some practice.
Here's another tip:
Sometimes when you cut a piece of wood, the power saw blade tears up the wood.
This is true with your hardwood cuts.
So let's say I am going to cut a 1x6 oak across the grain.
Oak is brittle and it chips with a crosscut, especially with a dull blade.
Use the square to draw a line across where you want your cut.
Bring the square back just a little from the mark ... maybe 1/32 inch ... then score the wood with a sharp utility knife.
Let the blade run along the square for a nice straight line.
Now when you cut your board, and the oak chips out, the little chips stop at the score line.
9/28/2019 7:57:15 AM • Stanley 46 - 071... • Answered on Sep 28, 2019
Stanley Fatmax 1000 Peak Amp Power Station. How do you turn off the backlight please?
Question edited for clarity. The LED Area Light or the Unit display. The backlit display always stays on to alert you to the internal battery status, so that when you come to use it, it should be fully charged. https://www.manualslib.com/manual/2188388/Stanley-Fatmax-Pp1dcs.html?page=2&term=light&selected=1#manual
12/10/2023 5:19:15 PM • Stanley... • Answered on Dec 10, 2023
2answers
The USB power will not stay on. Lights up briefly but thats all
I'm having same problem... anyone know?
11/16/2023 5:42:17 AM • Stanley... • Answered on Nov 16, 2023
My Stanley fatmax powerit 1000a won't turn on if it's not plugged in
replace battery. Check your manual that came with unit. copy and paste Stanley fat max power it 1000a battery
5/17/2022 6:34:57 PM • Stanley... • Answered on May 17, 2022
2answers
How to calibrate stanley 400mm digital level
Select a location that is relatively level and flat. The edge of a bench is best so that the level can be placed in the same position when the level is rotated during the calibration process. To calibrate follow below: Press and hold Calibrate button for about 4 seconds. The display will now show CAL1. Press the Calibrate button briefly again and the 1 will flash, a beep will be heard and CAL2 will be displayed. Rotate the level 180° end to end with the display still facing you whilst the level is now upside down. Place the level in the same location. Press the Calibrate button briefly one last time. The 2 will flash, a beep will be heard and the display will revert back to normal.
4/21/2022 10:02:27 PM • Stanley... • Answered on Apr 21, 2022
2answers
How to repair a Stanley powerlock 16 measuring tape ?
From the the attached photo I see that you have completely disassemble the tape. This makes the tape almost impossible to reassemble. The spring has to be back wound fully, the blade attached and retracted back into the case using the back wound spring. This requires special equipment that is not overly complicated, however not possible to make for a once off use. I have designed, built and trained operators to use this type of equipment in a production situation, however in my 35 years of experience I have never been seen anyone back wind a spring by hand. Sorry to say but the tape is ready for the trash.
7/20/2021 5:49:35 AM • Stanley... • Answered on Jul 20, 2021
Stanley fatmax powerit backlight will not turn off
stanley fatmax jumpstarter 1000A light wont turn off?
3/24/2021 7:20:57 PM • Stanley... • Answered on Mar 24, 2021
My new Stanley Fatmax Powerit model PP1DCS won’t charge.
TAKE IT BACK TO THE DEALER
8/14/2019 6:39:33 PM • Stanley... • Answered on Aug 14, 2019
Stanley stud finder AC sensor continually beeps on 10mm plasterboard wall
Most stud finders have a sensitivity adjustment that should be carefully adjusted per instruction manual before use. Failure to do this results in erroneous indications. If you have adjusted exactly per the instructions with the same result the unit is probably faulty.
4/4/2019 6:29:22 PM • Stanley... • Answered on Apr 04, 2019
My wife bought me Xmas 2018 a Stanley Fatmax Lithium ion LED Spotlight FL5W10 600 lumens. The bright portion of the LED has quit working. What are my options - has only been 3 months.
here is the website:https://www.stanleytools.com/products/hand-tools/flashlights-lighting/spotlight/waterproof-led-rechargeable-spotlight/fl5w10and they say the warranty is 1 year:Warranty1 Year Limited WarrantyThe manufacturer, Baccus Global warrants products against defects in materials and workmanship for a period of ONE (1) YEAR from the date of retail purchase by the original end-user purchaser ("Warranty Period").If there is a defect and a valid claim is received within the Warranty Period, the defective product can be replaced or repaired in the following ways: (1) Return the product to the manufacturer for repair or replacement at manufacturer's option. Proof of purchase may be required by manufacturer. (2) Return the product to the retailer where product was purchased for an exchange (provided that the store is a participating retailer). Returns to retailer should be made within the time period of the retailer's return policy for exchanges only (usually 30 to 90 days after the sale). Proof of purchase may be required. Please check with the retailer for their specific return policy regarding returns that are beyond the time set for exchanges. Please call 1-877-571-2391 for more information or return instructions.This warranty does not apply to accessories, bulbs, fuses and batteries; defects resulting from normal wear and tear, accidents; damages sustained during shipping; alterations; unauthorized use or repair; neglect, misuse, abuse; and failure to follow instructions for care and maintenance for the product.OOtherwise, check with the seller who sold it to your wife - If they are unwilling, and more companies seem to be going this route, go to the Manufacturer
3/4/2019 7:48:06 PM • Stanley... • Answered on Mar 04, 2019
Do I plug my stanley fatmax 450 with air compressor to house hold outlet to charge it or what?
Yes. Unless one was provided the standard is to just use an extension cord.
2/11/2019 8:26:47 PM • Stanley... • Answered on Feb 11, 2019
How to get the app to conect my stanley fatmax powerit 1000A to my phone.please help.
I have just read the device instructions and although the device offers usb charging or power up to half an amp it does not and cannot communicate digitally...
2/9/2019 8:58:47 PM • Stanley... • Answered on Feb 09, 2019
What is the select button used for on the Stanley fat max ?
Stanleyville
10/9/2018 7:46:19 AM • Stanley... • Answered on Oct 09, 2018
Stanley 46 - 071 Contractor Grade Quick Square Layout Tool Logo
1 questions posted
Top Stanley Measuring Tools & Sensors Experts
ADMIN Andrew
ADMIN Andrew
Steve Pack
Steve Pack
ADMIN Eric
ADMIN Eric
Are you a Stanley Measuring Tool and Sensor Expert? Answer questions, earn points and help others
View Most Popular
  • Stanley Measuring Tools & Sensors
Most Popular Question
dont know all
  • Measuring Tools & Sensors
