20 Most Recent Craftsman Stud Finder withLed Display Questions & Answers
Craftsman stud finder not working
It's probably broken.You can buy a new stud finder.
9/21/2012 6:28:24 AM • Craftsman Stud... • Answered on Sep 21, 2012
Craftsman 4 in 1 laser level. Batteries corroded. Can I open it up safely to clean inside ?
Yes of course as long as the battery is removed.
3/5/2023 5:09:02 AM • Craftsman... • Answered on Mar 05, 2023
Craftsman 320.48247 laser level not working with new batteries
If your Craftsman 320.48247 laser level is not working with new batteries, there could be a few different issues causing the problem. Here are a few things you can try to troubleshoot the issue:
  1. Check the battery connections: Make sure the batteries are properly installed and the connections are clean and secure. If the batteries are not making good contact with the terminals, it can cause the laser level to malfunction.
  2. Check the battery type: Make sure you are using the correct type of batteries for your laser level. Using the wrong type of batteries can cause the laser level to malfunction.
  3. Check the laser diode: If the laser diode is damaged or not functioning properly, it can cause the laser level to malfunction. You can check the laser diode by inspecting it for any visible damage or looseness and making sure it is properly aligned.
  4. Check the lens: If the lens is dirty or damaged, it can cause the laser level to malfunction. Clean the lens with a soft, dry cloth and make sure it is not damaged or cracked.
  5. Check for any other visible issues: Inspect the laser level and its components for any visible issues that may be causing the laser level to malfunction. This can include debris or foreign objects that may have gotten stuck in the laser level, or damage to the laser level or its components.
If you have tried these troubleshooting steps and the problem persists, it may be necessary to have the laser level serviced by a professional. A technician will be able to diagnose the problem and determine the necessary repairs.
12/26/2022 12:12:08 AM • Craftsman... • Answered on Dec 26, 2022
Looking for repair manual or help with problem
ok,there are 3 safety switches,(i have the same mower,i bought for 50 bucks because they couldnt start it),a seat switch in case you fall off,a brake/clutch switch,so you have to step on it to start and a deck switch,so if your deck is engaged,it wont start,if you can guarantee that you wont fall off or screw around and get your foot cut off,i will tell you how to bypass the safety switches, pull the cover off the motor,see the single small black wire connected to the coil?not the spark plug cable,pull that wire off of the coil,now,find a switch that you can use for a shut off,connect a wire to the coil and run it to your dash,connect another wire to ground,connect each of them to either side of the switch,you will use that to stop the motor,put the cover back on,sit in seat,push in clutch and start your mower.be careful,there are no safety switches now,dont go up a hill sideways you will get killed if it rolls on you.
7/19/2015 4:25:23 AM • Craftsman... • Answered on Jul 19, 2015
0answers
2answers
Need user manual for w5746
Same exact features, buttons and functions as this manual by Irwin.
http://www.irwin.com/uploads/documents/36_laser_tape_25.pdf
4/17/2024 8:59:53 PM • Measuring Tools... • Answered on Apr 17, 2024
Craftsman Stud Finder withLed Display Logo
2 questions posted
Top Craftsman Measuring Tools & Sensors Experts
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you a Craftsman Measuring Tool and Sensor Expert? Answer questions, earn points and help others
View Most Popular
  • Craftsman Measuring Tools & Sensors
Most Popular Question
craftsman stud finder not working
  • Measuring Tools & Sensors
