20 Most Recent
Electrolux EOB6632 Electric Single Oven Questions & Answers
Oven switches 'itself' off without the timer
I sorted it it is a simple solution, if you take the top of your oven you should see the problem...it will be big and black..dont spend a ortune getting it sorted i brought the part off ebay for less than a fiver..
just cant remember what it was called..very simple to fix though.
Mike
I have a Electrolux EOB5630.
Hello & Welcome to FixYa
This indicates a open/shorted oven temperature sensor and to solve this problem the sensor needs replacement. If you wan to be sure before replacing the sensor then you can test it with a voltmeter for around 1100ohms....if it reads more then this then it needs replacement however, if the reading is around or less then 1100ohms then it is the thermostat that needs replacement. Please get back to me if you have any other questions.
Kevin
Electrolux EOB 6632 oven trips
Hi, welcome to FixYa! my name is Shaun. I hope i can help you out with your question. Your main house breaker is tripping over 180C because of the amount of current your oven is drawing. Keep in mind that an oven is capable of pulling up to 1/4 the amount of amperage of your total house current capacity, up to 50 Amps. This is assuming you have a typical 200 Amp main breaker. Add this in with your heating/air-conditioning, up to 30A, if electric, your water heater, 25 A if electric, and whatever lights and appliances you have plugged in and turned on, you can imagine how quickly those amps add up when your oven is on. Your oven breaker won't trip because you're not exceeding 50A on that circuit, however if your total household load is exceeding 200A, your main will trip. Also, breakers lose efficiency over time. Sometimes they can drop current capacity by as much as 25%. So your best bet is to replace your house main and see if that fixes your problem. Hope this helps out. Have a good day!
After 30mins the oven goes off, what is the
Hello,when you opened the top you will find a small insulated plastic tube with two
thermostats in side and maybe one of them was burned out,this assembly
must be replaced with a new one ,they are all push on connections and
are easy to replace turn the cooker switch off for oblivious safety
Thanks
We had a power surge, and since then the control
Hi
Make sure that the control panels wire harness contact clips that are behind the actual control board are lose or destroyed, if such then replace the entire harness.This could be the main reason for the lights that are not illuminating during operations. If the wires and the harness or the contacts are in good condition,then this could be a circuit issue inside the control board, related to the LEd lights.Replace heat damaged capacitor labeled C3 on display board.
Thanks for contacting fixya.com
Oven Switching Off
I have a few questions. Does the oven reach the set temperature? How do you get it to go back on? and if you do not set the time do you have the same problem?
Electrolux Oven 5d or Sd error code/demo mode
- Turn off the oven.
- Press and hold the "Bake" and "Broil" buttons.
- Turn the oven on by pressing the "On/Off" button.
- Continue holding the "Bake" and "Broil" buttons until the display shows "PF" or "8.88."
- Release both buttons.
If these steps don't work, refer to the user manual or contact Electrolux customer support for further assistance.
