20 Most Recent
Zenith Z52SZ80 TV Questions & Answers
Tv went off and wont come back on just had bulb replaced fan is on but no power indacater on front
OPPS!You may have damaged the lamp or the ballast that drives the lamp.Confirm the model and brand to me:All sets that use a lamp warn you to if you turn set off NOT to unplug it for several minutes until the fans in set all shut off.What can and does happen is when set turned off the fans continue (especially the one on the lamp) to run until the lamp cools down to a specific temperature---unplug it before that and the lamp can instantly be damaged or even destroyed.
Zenith dlp projection t.v. model#z52sz80 t.v. turns off randomly
This solution is for the zenith 56" DLP. Unplug the tv, either from the wall socket or the TV. While the TV is unplugged hold the power button on the TV for 40 seconds. This lets the excessive power drain from the TV. If this does not work call 1-800-243-0000. This is the number for their help line. This is the fix the tech gave me and it worked right away. Hope this helps and have a great day.
The tv wont turn on and there is a short buzzing
If the buzzing noise sounds like a fork in the microwave, it's time for a new lamp. If it sounds like a squealing noise, it's either a fan or the color wheel. Color wheels are not easy to replace, so I recommend hiring a Service Tech.
Hi needing help in seeing
your lamp has gone out. you need to replace it.
Z52SZ80 lamp
part # 6912B22007B
you can get it online for about $129, just google it. easy to install.
