20 Most Recent
Oki Electric Industry OKI C710dn - - color - duplex - LED - Legal, A4 - 1200 dpi x 600 dpi - up to 32 ppm /... Laser Printer Questions & Answers
B720 stuck on initializing
Shut printer off
Press Menu and Online buttons while powering back on
Press enter to format memory
Printer will request to be powered off
Power off and then back on. It should boot past the initializing screen and be fully functional.
Oki c710 error 980 reset
Per the technical manual - Media wrapped around the fuser error. Turn off the power. Replace the fuser....
It is possible to unravel the paper from the fuser.
How do i reset the drum unit on my oki c710?
When the image drum cartridge reaches the 90% point of its life cycle on an Oki Data laser printer, a "Change Drum" message will display on the screen. Around this time the print typically starts to become faint or starts to deteriorate. When a new drum cartridge is installed, the drum cartridge counter needs to be reset for the printer to keep track of the life cycle of the replacement.
1.Turn the printer power off. Open the top cover.
2.Press the oval switch on the operator panel. Hold the switch down. Turn the printer power on.
3.Release the oval switch when the lights on the front panel flash twice. This indicates that the drum counter has been reset. Close the printer top cover.
Hi, recently bought an Oki c710 printer (not the
Try this:
While printer is off, hold down plus "+" and minus "-" keys then power printer on and continue to hold the + and - keys until "System Maintenance" appears on the display (you will see "please wait", "initializing", "ram check" before it appears).
When System Maintenance appears press Enter. You will be prompted for a password. The default password is "000000" (six zeroes). [Use the minus key for quicker access to the zeroes and press enter twice after the last zero to enter the menu.]
HOW DO I RESET THE FUSER ON AN OKI C710
Check online for a fuser kit for your machine, OKI machines use a fuse installed on the new fusers that reset the count and then burn out. The fuse is Littlefuse #251-062
