20 Most Recent K2 Cinch CTC Snowboard Binding Questions & Answers
2answers
K2 Cinch loop leash on top of highback tore. What
The K2 website has a binding technical manual, link was found at the bottom of the K2 home page (see link below). The manual provides NO part numbers and NO repair procedures, but the repair is fairly easy.http://assets.k2sports.com/k2snow/ftpk2snow/2017/catalogs/k2snowboarding_binding_tech_manual.pdfThe back straps on the K2 Cinch are called "grab loops" as shown in photo below.If both “grab loops” are broken, take a few photos first so you can recall the routing for installation of the new “grab loops”.These "grab loops" are held in by two silver coloured roll pins which can easily be tapped out with a small nail & hammer. If the pin doesn't come out easy, tap from the other side of the pin. The pin has a head on one side.You may need to use pliers to remove the broken piece of strap from the top lever.Take the broken strap pieces to your K2 retailer ( snowboard shop) and ask them to order a new strap. K2 info suggests you can’t order parts online direct from K2, so you have to order through a K2 retailer.Use your other binding with the good strap to copy the routing of the new strap. You might want to order two new grab loop straps and change them both while you are at it. ??25175ede-8e08-4188-8618-006758d7753a.jpeg
12/3/2017 12:41:41 AM • K2 Cinch CTC... • Answered on Dec 03, 2017
Cinch K2 binding strap. My bndings are only two
Here is the manual for the bindings.I have the OG Cinch bindings, got them in 2004 I think and they're still holding strong. Heavy but I love them! http://assets.k2sports.com/k2snow/ftpk2snow/2017/catalogs/k2snowboarding_binding_tech_manual.pdf
10/22/2017 4:39:25 AM • K2 Cinch CTC... • Answered on Oct 22, 2017
Require a new bracket that holds the cable on the
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
8/13/2010 12:38:42 AM • K2 Cinch CTC... • Answered on Aug 13, 2010
Rear leg high back comes undone/releases when i pop
It sounds like either one of two things, with the high back. Take the adjuster off and check the teeth to see if it is stripped. If it is, Go to your local hardware store and pick up some locktite epoxy. It will be a permanent bond, but that will make them usable. The other chance is maybe it needs to be torqued down. With the possibility of your foot popping out that sounds like you bindings are not set up correctly. I had a pair hit a rock off a bc kicker, ripped the adj, off. and still was securely held down. If you are not sure how to set it up, hit up your local board shop
5/8/2009 9:26:10 PM • K2 Cinch CTC... • Answered on May 08, 2009
I have a 2006 Polaris 900rmk snowmobile it keeps overfueling at idle I believe it is one of the injectors on pto side not sure which one of the 2 affects your idle any ideas?
they both can repair manual show how to trouble shoot --------https://snowparts.ru/manuals/Polaris%20Trail%20600-900%20RMK%20Switchback%20Service_Manual_2005.pdf
1/10/2023 1:06:51 PM • Winter Sports • Answered on Jan 10, 2023
No spark on 02 ski doo legend
You have a bad coil or wire.
1/3/2023 2:25:15 AM • Winter Sports • Answered on Jan 03, 2023
2answers
Spark plug gap on a 2006 Polaris 700 Classic
It depends on the brand of spark plug you are using. https://www.google.com/search?q=2006+Polaris+700+Classic+spark+plug+gap ..
12/18/2022 3:53:35 PM • Winter Sports • Answered on Dec 18, 2022
2answers
Wearfit 2.0. Why can't I bind to my iPhone?
Discord users facing issues like How To Fix Discord Not Opening so just make a call on Discord Customer Support 1-802-618-6092 anytime and experts are there on Discord Live Chat to help you 24*7 . Need any kind of guidance to fix the Discord issue so just make a call on Discord customer Service 1-802-618-6092 anytime and fix issues, a helpdesk is there to help you 24*7
2/24/2022 9:59:23 AM • Winter Sports • Answered on Feb 24, 2022
2003 Ski-Doo Grand Touring 550 Fan. All of a sudden I have no spark! What could be the problem?
kill switch --ign switch--cdi--magneto--broken wire --etc https://ski-doo-snowmobile.brssm.com/ https://www.snowmobilerepairmanual.com/ski-doo-repair-manual/
1/16/2022 5:08:05 PM • Winter Sports • Answered on Jan 16, 2022
Skandic Skidoo. How do I take out a battery that is located underneath the seat of a Skandic Skidoo
Question edited for clarity. Question moved from Seat Cars (Spanish car maker and pronounced See-at) to Snowmobiles Category. The are videos and text based articles. The best bet is to fit pigtails to the battery and had a plug for a battery maintainer. You never have to remove the battery, and you never have to worry about it it not being charged. https://www.google.com/search?q=skandic+skidoo+remove+battery ..
1/15/2022 10:33:14 PM • Winter Sports • Answered on Jan 15, 2022
2012 Switchback adventure 600
MAYBE IT NEEDS SOME OIL ADDED
1/4/2022 7:51:27 PM • Winter Sports • Answered on Jan 04, 2022
3answers
What types of waxes are used in cross-country skiing?
There are four different types of waxes that are used: waxtapes, glide waxes, klisters, and kick waxes.
6/25/2021 3:58:02 PM • Winter Sports • Answered on Jun 25, 2021
1991 Polaris Indy 500 Classic. How do you remove the chain case? It seems to be holding on the top?
I fixed the question and put you in the Snowmobile category Video instructions here https://www.google.com/search?q=1991+classic+500+replace+chain ..
6/4/2021 3:46:08 PM • Winter Sports • Answered on Jun 04, 2021
2007 Arctic Cat F1000. Why does it keep stalling while being ridden?
It could be many different items, choke stuck, ignition switch etc. but more importantly have you taken care of your recall? https://www.cpsc.gov/Recalls/2017/Arctic-Cat-Recalls-Snowmobiles
4/29/2021 5:05:37 PM • Winter Sports • Answered on Apr 29, 2021
Ski Doo. Where can I get a repair manual?
Try contacting Ski Doo directly to inquire.
1/23/2021 8:50:35 PM • Winter Sports • Answered on Jan 23, 2021
1996 Yamaha Vmax XT 600 snowmobile. How can I replace speedometer cable?
Unscrew it from the back of the speedometer and follow it back to where the cable terminates at the hub of the track. Undo it there and replace it with the new one. https://www.google.com/search?q=1996+Yamaha+Vmax+XT+600+snowmobile.+How+can+I+replace+speedometer+cable ..
1/19/2021 6:18:29 PM • Winter Sports • Answered on Jan 19, 2021
When do questions usually get answered?
6 months to a year after they are posted. not always but a lot lately !!
12/6/2020 4:58:52 PM • Winter Sports • Answered on Dec 06, 2020
K2 Cinch CTC Snowboard Binding Logo
Popular Tags
11 questions posted
Top K2 Winter Sports Experts
Arnie Burke
Arnie Burke
john h
ADMIN Andrew
ADMIN Andrew
Are you a K2 Winter Sport Expert? Answer questions, earn points and help others
View Most Popular
K2 Winter Sports
  • K2 Winter Sports
Most Popular Question
k2 cinch loop leash top highback tore
  • Winter Sports
