When the switch is ON, the light operates in dusk-to-dawn mode. In this mode, the light automatically turns on at sunset and turns off at sunrise. When the switch is off, the light stays off.
Press P (program )on the timer and display will show then change the desired day, time and minute using the D+, H+ and M+ buttons. Press P again to set up another program and repeat the second step as above
Clear memory by pushing the reset button on the timer then reprogram using your current schedule when you want the timer to go off/on. Use the day and clock buttons for this then press enter
No, the timer should not make any noise. The noise should be a result of loose connections which cause arcing, which can make a humming or buzzing sound.
If you find that you still notice the sound, even when the main breaker is off then the problem is not electrical in nature.
Question edited for clarity and add a header in order with spaces and CAPS.
It appears Micromark got out or the timer business. There is a similar one in another Fixya post, and a link to them.
https://www.google.com/search?q=Micromark+MM+9565+timer
OXOhttps://www.oxo.com > wysiwyg > PDF_Files
PDF
The clock is set. • To set timer, press any button to enter timer mode. A timer icon will appear on the LCD screen. Press the and buttons to set the timer.
1 page
The Sharp Air Conditioner Remote Control CRMC-A310JBEO comes with two timer-related functions: TIMER ON and TIMER OFF. To set the timer on the remote control, press the Timer button, then use the Temp + or Temp - buttons to set the desired time. Wait 3 seconds, then the timer function will be activated. You can turn off either function by setting its timer to "0.0h".
