20 Most Recent
Sharp EC-S2365 Upright Vacuum Questions & Answers
Sharp ec-14twt6 won't start
if the motor spindle spins easily when turned by hand, the motor brushes need replacing. if it doesn't, either something is stuck in the turbine, or the motor is siezed. if the motor is siezed, it needs to be replaced.
Moter gets hot Sharp vacuum # NV350E
Check to see if there is an obstruction in the hose. Sometimes the lower section gets blocked and when there is no or little air flow the motor will heat up.
Sharp r-530es microwave.
when depressing
Hello there, the mechanism for opening microwaves is such that when the button is depressed it raises the hooks which hold the door back. In some microwaves the hooks also have another part which pushes the door out while some units have door hinges which have spring mechanisms which pushes out the door. Depending on what is obtainable on your unit the problem might differ. What you want to do is this, when the door is open press the button and see if the hooks which are supposed to hold the door in place move as expected but considering that the door opens when you pull the problem is more likely from the spring mechanism which is supposed to push the door out.
Try cleaning the hinges and the space in between the door and the control panel. Try this and let me know as any other process might require a replacement part.
Hope this solution has been helpful?
Thank you for visiting FixYa.
