20 Most Recent Relic Degrade Pocket Watch Questions & Answers
How to set the time and day and date on a relic zr15701
Pull the crown out once to set the date. Pull it out a second time to change the time. Of course move the crown up or down and see if it will change.
12/26/2013 5:29:53 AM • Relic Degrade... • Answered on Dec 26, 2013
0answers
2answers
How to set the time on relic watches
I had to go to the Sears counter to fix mine. The sales person had to use TWEEZERS to pull the serrated knob up. He had to really work at it. Once it is pulled up you can twist the knob to set the time and then push the knob back down. What a stupid design.
12/18/2010 3:34:07 AM • Relic Degrade... • Answered on Dec 18, 2010
I have a cheap pocket watch that needsa new
Pocket watches are 99% with the back snap-on/sanap-off opening. Never came across the screwback. Get the knife with the solid blade, insert the blade in the groove between the case and the caseback and push it in quite hard using lever action (pry up). At the same time make sure the blade do not slip into the movement, as it will damage your watch.
If there is no groove between the case and the caseback, then watch must be opened by removing bezel (metal ring holding glass in place). Open the same way as for the caseback, just be VERY carefull, as any slip of the blade will leave the marks on dial.
Do not forget to rate, please.
2/28/2009 2:09:19 AM • Relic Degrade... • Answered on Feb 28, 2009
Some of the numbers on my relic pocket watch fell off.
Unfortunately you will not be able to get the watch glass off without braking it. Watch glasses usually are friction set or glued into the watch bezel using special press or special glue. Both are of such a good quality, that it is allmost impossible to remove the glass without special equipment.
You can try, of course, but it will be on your own risk.
The best way is to find your nearest watch repair shop and ask for help.
2/10/2009 3:14:44 PM • Relic Degrade... • Answered on Feb 10, 2009
What replacement battery is needed for a Relic Wet ZR15352250206
From my research, the Relic uses an SR920SW.
1/1/2024 8:02:45 AM • Relic Watches • Answered on Jan 01, 2024
How to set the 24 hr time on a women's relic multifunction Zr15992
What company made this watch? The only watch I can find with that name is not a digital watch so the 24 hour display does not possibly apply. Are you referring to the date display not changing at midnight? A quick trick that might work is to Roll the 12 hour dial forward 12 hours, (example 12 noon forward to 12 midnight). The dual time display is for when people are using two different world time zones. For example, for people who work regularly in two different countries. Using it means you don't have to keep reseting your watch when you change countries.
7/19/2023 6:20:26 AM • Relic Watches • Answered on Jul 19, 2023
2answers
I have a relic brand watch model ZR11957 and can't get the back to attach properly after changing battery, how do I fix it?
Did you use a small blade and pry between the back and a small indentation on the rim of the watch to pop it off? If so, its a pressure fit. There should be a rubber gasket around the back, make sure its there and in good shape. Place the watch face down on a pad similar to a rubber computer mouse pad, properly align the case slot with the crown stem and place into position, using both thumbs push down on the back, it should snap into place.
4/30/2022 1:04:16 AM • Relic Watches • Answered on Apr 30, 2022
2answers
What size battery do a relic zr11787
Take your Relic watch to a jeweler who will identify the type (not size) and may replace it.
8/7/2021 12:52:32 AM • Relic Watches • Answered on Aug 07, 2021
How do I replace the backing of A woman's Relic watch
Take your watch to a jeweler for a demonstration.
8/3/2021 7:24:53 AM • Relic Watches • Answered on Aug 03, 2021
Relic Degrade Pocket Watch Logo
Popular Tags
13 questions posted
Top Relic Watches Experts
NOEL
NOEL
ADMIN Andrew
ADMIN Andrew
deton8 von Splosion
Are you a Relic Watch Expert? Answer questions, earn points and help others
View Most Popular
Relic Watches
  • Relic Watches
Most Popular Question
set time relic watches
  • Watches
