20 Most Recent Stiebel Eltron DHC 10-2 Electric Tankless Water Heater Questions & Answers
Hi, I just got my
This electric demand water heaters has one heater element. The flow switch turns it on. The thermostat cycles it on and off according to temperature. There is no medium. You need to run the sink on hot while you take a shower. This kind of cancels out the savings on electricity. Or get a higher flow shower head. Your screen on the shower head may be partially fouled. Here is the brochure. It shows the flow rates for the different models. http://www.stiebel-eltron-usa.com/sites/default/files/pdf/brochure-dhc.pdf
12/31/2017 12:08:00 AM • Stiebel Eltron... • Answered on Dec 31, 2017
0answers
Stiebel Eltron 221094
Stiebel eltron model 221094 hot water is not as hot as it was before, only warm water coming through. Do I need to replace unit?
12/11/2013 5:47:26 AM • Stiebel Eltron... • Answered on Dec 11, 2013
Hi my heater is making
Don't worry there is nothing wrong with the water heater making a clicking noise, mines does that too.
Thanks
6/3/2011 7:15:39 PM • Stiebel Eltron... • Answered on Jun 03, 2011
MY HEATER IS DCH-E10...... EVER SINCE I PUT IT IN
You need to replace the high-limit reset switch on your Stieble Eltron DHC 10-2 Electric Tankless Water Heater.
12/14/2010 10:56:15 PM • Stiebel Eltron... • Answered on Dec 14, 2010
2answers
Stiebel Eltron DHC 6-2 tankless water heater. Can I reduce the power of it?
Ideally it needs to be on a separate breaker. Surely there is more than one breaker in the apartment. The only way to fix what you have would be to change the element for one with a lower wattage but unfortunately the element is not listed as a spare part. Phone the company and tell them the problem as there may be an issue with your heater shorting out somehow. https://www.stiebel-eltron-usa.com/sites/default/files/pdf/parts-dhc.pdf Others have the same issue! https://www.google.com/search?q=Stiebel-Eltron+DHC+6-2+tripping+breaker ..
5/25/2023 1:31:02 AM • Stiebel Eltron... • Answered on May 25, 2023
Model DHC 6-2 tankless. It heats a little but then why does it shut down?
possible bad heating element
4/5/2022 6:23:20 AM • Stiebel Eltron... • Answered on Apr 05, 2022
2answers
Stiebel Eltron DHC-6. Could the 220 volt breaker be the cause for the heater to provide lukewarm water and turn off?
only getting one side of the 220 so half the heat
2/28/2022 4:37:09 AM • Stiebel Eltron... • Answered on Feb 28, 2022
My stiebel eltron has no power
Is the circuit to the heater hot?
10/29/2021 7:37:07 AM • Stiebel Eltron... • Answered on Oct 29, 2021
Where to buy online the thermal cut out for Stiebel Eltron Tankless Heater part# 162474 ??
Direct from the maker
DHC Series Spare Parts List & Diagram - Stiebel Eltron
https://www.stiebel-eltron-usa.com > files > pdf
PDF Heating system. 165889. 167769. 167770 ... Safety thermal cut out. 162474. 162474. 162474. 162474. 162474. 162474. 162474. 162474. 162474. 9. Wiring block. 1 page
8/12/2021 2:30:27 AM • Stiebel Eltron... • Answered on Aug 12, 2021
Trying to install Stiebel Eltron tempra plus 24 water is leaking out both going in and going out hoses how do I fix this
CONTACT THE SELLER , WE KNOW OF NO SOLUTION FOR YOU
4/19/2021 3:23:04 AM • Stiebel Eltron... • Answered on Apr 19, 2021
My Stiebel Eltron DHE18 is 4 years old, always worked great, and still under warranty. However the water remains ice cold and the flow indicator on the display says o.o L/min
If it is under warranty, just contact the company to diagnose and fix it. The most likely cause is a failed thermostat or element, but as the flow rate is also incorrect, it may be a control board issue. This unit only seems to be available in Australia. We are in North America :>) SERVICE-HOTLINE +49 55 31 - 70 20
DHE 18/21/24 Convenience instantaneous water heater of ...
https://www.stiebel-eltron.com > home > dhw > dhe_18...
The DHE comfort instantaneous water heater from STIEBEL ELTRON guarantees high energy efficiency. Full electronic output control with 4i technology enables ...
DHE Instantaneous 3 Phase Water Heater - STIEBEL ELTRON
https://www.stiebel-eltron.com.au > dhe-instantaneous-3...
DHE 18 AU / DHE 27 AU · Made in Germany · Precise hot water temperature up to 60°C with 4i Technology · Instant and continuous flow of hot water · Electronically ...
DHE 18 SLi 25A Convenience instantaneous water heater of ...
https://www.stiebel-eltron.in > dhe_sli_electroniccomfort
Convenience instantaneous water heater DHE 18 SLi 25A of STIEBEL ELTRON ? Product information from the manufacturer, technical data, operating ...
4/2/2021 4:46:22 PM • Stiebel Eltron... • Answered on Apr 02, 2021
Stiebel Eltron DHC 10-2 Electric Tankless Water Heater Logo
Popular Tags
10 questions posted
Top Stiebel Eltron Water Heaters Experts
littlewheel
ADMIN Andrew
ADMIN Andrew
Are you a Stiebel Eltron Water Heater Expert? Answer questions, earn points and help others
View Most Popular
  • Stiebel Eltron Water Heaters
Most Popular Question
just got
  • Water Heaters
