20 Most Recent Archos 5 MP3 Player Questions & Answers
0answers
Archos5 register
How did you get your archos, if you can't register call this number for archos tech support.
Our toll-free number is: 1-877 300 8879
Hours : daily 7:00am - 11:00 pm CST, 7 days a week
5/3/2014 6:09:40 PM • Archos 5 MP3... • Answered on May 03, 2014
2answers
Is there a way to wipe an Archos 5, 120 gb clean
Deleting Files,Pictures,etc from MP3 Player
Hook up your mp3 player to your computer Go to your desktop and double left click on "My Computer" When it opens you will see listing that says "Devices with Removal Storage" your mp3 player should be listed there. Right click on your mp3 player, and a window will open, right click on "Open" and now your files/songs should be visible. Hold the left click down and drag it across all the files/songs that you do not want this will highlight the files/songs you do not want, release, right click and then click on "Delete" Now you mp3 player should be clear of the files/songs you do not want. Be careful and do not delete files needed to operate your MP3 player. Good Luck, I hope this helps Please rate me, Thank You
2/18/2013 1:41:43 AM • Archos 5 MP3... • Answered on Feb 18, 2013
Dear friends I have archos 5
Your media player should have a micro SD flash card in it. Your information should be stored on there so you information will be safe. You can purchase an SD adapter that your micro SD card can go in so you can use that with your PC. This way you can access the information. Hope this helps.
3/22/2011 11:27:47 PM • Archos 5 MP3... • Answered on Mar 22, 2011
Hi, Please could you advise how much it will cost
Contact one and ask, but a cost of up to $100 should not surprise you.
A battery replacement should be easy to give a quote on.
1/31/2011 12:26:23 PM • Archos 5 MP3... • Answered on Jan 31, 2011
My archos7 won't delete a move that Iwant off
You should higligth the movie and press option button on top rigth File management/ delete. This is performed without a pc connection from the Archos itself
1/23/2011 8:46:15 AM • Archos 5 MP3... • Answered on Jan 23, 2011
2answers
Sir , i have one archos5 and i want install flsh
boa tarde gostaria de saber se tem como me ajudar pois tenho um archos 5 e ele aparece o code 108 mais ele nao me deixa nem reparar o disco e nem formatar ele sempre quando escolho uma das funcoes ele reinicia e so fica congelado na tela de apresentacao da archos
5/11/2010 7:59:47 PM • Archos 5 MP3... • Answered on May 11, 2010
Archos 5 not working, will not switch on.
Hi I would think the best place to start is with ARCHOS,
give them the lowdown and see what they come up with.
You could use the Archos forum and look through the help files
4/13/2010 12:05:13 PM • Archos 5 MP3... • Answered on Apr 13, 2010
2answers
I just got my Archos 5 120gb unit today, while
try to connect charger and if also it doesnt boot so ask the shop if they can replace
12/29/2009 8:25:19 PM • Archos 5 MP3... • Answered on Dec 29, 2009
File system error: FAT is corrupted
Your hard disk on your media player is corrupted which also does happen on a normal PC/Laptop. To fix it, use windows explorer -> right click on your mouse againt the media player drive -> select properties -> select 'Tools' tab -> select Error checking / Check now -> Tick on 'automatically fix file system errors and recommended also 'scan for and attempt recovery of bad sectors' -> Start.
At this point, you may also need to restart your PC/LAPTOP and then be patient as 120GB is a fairly large drive to repair! Once the FAT has been repaired, depending on the corruptions, you may need to replace some songs, video, photos or other files.
ps. the other 'drastic' option is of course to reformat the whole Media driver drive !!!
12/20/2009 2:23:35 AM • Archos 5 MP3... • Answered on Dec 20, 2009
3answers
I recently purchased an Archos
Well you need to download the Flash player, the flash logo comes when some flash file need the flash software to play that file..... so you just click on that logo and follow the download instructions after downloading the flash software just install them.
post further comments for more help or information....
Good Luck!!
Thanks
12/10/2009 10:22:46 AM • Archos 5 MP3... • Answered on Dec 10, 2009
I CAN RECORD FROM MY TV BUT I CANT GET MY ARCHOS 5
You should swtch your TV to the video mode on to the video output chosen for the device. Check the video connecion type by following the output cables from the DVR station or charging dock to to TV. it could be video 1, 2, 3 HDMI, Color stream HD1 , Color stream HD 2, by scrolling down on the video mode list you should get the picture on on of them with correct video mode. or like i was saying follow the output cable from dvr station to Tv to see which video mode it was connected.
9/14/2009 7:49:40 PM • Archos 5 MP3... • Answered on Sep 14, 2009
I have an archos 5 and and it stay on the begging screen
try hitting the reset button as a first step when it comes on. You might have to do a hard reset. Make sure you have either your original firmware or the latest from Archos saved on your desktop. When you do a hard reset if it comes to the Archos screen hold down the volume+ button until the white recovery screen comes on. If you have data you don't want to lose in it you might be able to save it if you try the repair or recovery function but if they don't work you will lose everything if you have to format. You probably will have to format sorry for the bad news but try everything first before formatting.
8/24/2009 2:47:40 PM • Archos 5 MP3... • Answered on Aug 24, 2009
What add on do I need to get internet access
First you need to find a unsecured hot spot like McDonalds. If it is not unsecured you can not get on to the internet. There is no addon's that you can get to help get online.There are a lot of places Malls, Starbucks but stay away from places that want a credit card LOL.
8/24/2009 2:34:08 PM • Archos 5 MP3... • Answered on Aug 24, 2009
Hi,my archos5 start up repeatedly, how can i do?
You might want to try hitting the reset button when it comes on. the reset button is on the bottom next to the connectors you will need a paper clip. I hate to say it but you probably have to do a hard reset. Have you downloaded the latest firmware make sure you have either a copy of your original firmware or if you don't know which is your original firmware download the latest & save it to your desktop. When the archos screen comes on hold the volume button until the white screen with repair,recovery or format comes on first try repair or recovery your last choice is to format. Usually a hard format fix's most problems. I hope I have been helpful.
8/24/2009 2:27:43 PM • Archos 5 MP3... • Answered on Aug 24, 2009
2answers
My computer windows 8 wont recognize my archos 104.what do i do?
Windows 8 is and has been obsolete and unsupported for over 8 years. Time to update your OS. Linux is excellent, Ubuntu Mint is free and easy to use, the choice is yours.
12/14/2023 12:21:45 PM • Archos Audio... • Answered on Dec 14, 2023
Archos 605 wifi lcd screen keep turn off
If your Archos 605 WiFi LCD screen keeps turning off, it may be due to a few reasons:
  1. Battery issues: If the battery is low or has a poor connection, the LCD screen may turn off intermittently. Try charging the battery fully and checking if the problem persists.
  2. Power settings: The device may be set to turn off the LCD screen after a period of inactivity. Go to the device settings and adjust the power settings to keep the screen on.
  3. Firmware issues: If the firmware is outdated or corrupted, it may cause the LCD screen to turn off. Try updating the firmware to the latest version available.
  4. Hardware issues: If none of the above solutions work, it may be a hardware issue with the LCD screen or its connection. You may need to take it to a professional technician to diagnose and fix the problem.
I hope this helps!
2/28/2023 5:47:55 AM • Archos Audio... • Answered on Feb 28, 2023
Archos 5 MP3 Player Logo
29 questions posted
Top Archos Audio Players & Recorders Experts
 Grubhead
Grubhead
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Archos Audio Players & Recorders
Most Popular Question
sir one archos5 want install flsh
  • Audio Players & Recorders
