I know this thread is old, but I see no one answered the question - "How to remove the stand"
Grab the stand on the sides with your thumb on one side and fingers on
the other and pull down ... I had to "rock it out" or pull one end then
the other. It seems stuck but it will come off ... Another option would
be to take a small screwdriver and insert it in the small openings under
the standard gently push the tabs while pulling down on the side you
are doing. Push the tabs towards the outside of the unit not the inside
... in other words if you are working on the left hole push left (left
while viewing from the face of the unit)
SOURCE: How do I reset the time on my acu-rite model #
Hold the Time button until the hour blinks. When it does, use + or - to adjust. When correct, press Time again. This will cause the minute to blink - use the same buttons to adjust. When finished, press Time again.
SOURCE: My acu-rite keeps beeping even after a battery
I cut the wire that leads to the annoying noisemaker. Carefully remove the rear cover to expose the circuit board (the rear cover is connected to the circuit board so pull them apart carefully). Locate the noisemaker, mine was round and connected to the back cover with black and red wires. Cut the black and red wires and replace the rear cover. NOTE: If you use the alarm feature, it won't work anymore. I read on the Acurite site that the reason it beeps is because of interference with the wireless signal. They suggest not using one of your wireless devices. If you are like me, that isn't a good option.
SOURCE: I need instructions for my Model 00972 Acu-Rite
flashes continuously the time and the outside timp
SOURCE: I need a manual for
Here you go. May not stay up forever. http://www.weatherconnection.com/manuals/00592W.pdf
