Try this program:http://www.softpedia.com/get/Tweak/Unins... and disable automatic updates: START-> CONTROL PANEL-> AUTOMATIC UPDATES -> CHOOSE THE OPTION -> Turn off automatic updates <- :-)
SOURCE: victim of counterfeit microsoft software
sir it is possible that you got a pirated or counterfeited copy, you should reformat your drive and buy a licensed windows program. and use that to install your programs to you computer. thank you and fix ya.
SOURCE: software counterfeiting,did not pass genuine windows validation
This sort of issue takes place usually after windows updates
Therefore the best solution is to uninstall the recent updates on your computer and restart again.
SOURCE: you may be a victim of software counterfeiting.
Just click validate,enter the activation # and reactivate.
It does this if the activation file gets damaged,or if using pirated software.(if this is pirated software,you will need to get a genuine copy)
Please rate this fixya
SOURCE: 'you may be a victim of software counterfeiting
OK, This is a notice from Microsoft. The validation tool thinks your Version is a counterfeit. It is not a virus, but is still a headache no less. It will not go away, we can't shut it off. The only way to fix is to reload with a valid code or call Microsoft to report it. I hope this helps :)
message appearing on the screen that you may be a victim of software counterfeiting.this copy of windows did not pass geneuine windows validation. hiiii this is msg displayed on my screen
software counterfeiting,did not pass genuine windows validation problem,
