31 Defective toner cartridgeor missing cartridge 1. Verify that the toner cartridge and PC kit are correctly installed. 2.Wait 10-20 seconds for the printer to verify the units. 3. Replace the toner cartridge or PC kit if necessary.
Did you replace the toner cartridge with a Lexmark new or factory refurbished cartridge?
If not, then more than likely that's your problem. Lexmark put smart chips in the cartridges that prevents there re-use unless these chips were either replaced or scrubbed clean.
If this is a factory new or refurbished cartridge, contact Lexmark.
The cartridges are chipped differently for different printers even though the cartridge bodies look the same. You need to find a chip for the Lexmark cartridge to put on the Toshiba, then maybe it will work.
Yes you understand, it is problem Toner chip.When finished your toner then it chip has been disable.It is a technical policy.If you can refill it and again use.You must be reset the chip.Help www.chip resetter.com
los cartuchos de toner de lexmark x340 utilizan un chip que sirve como referencia de que se ha colocado una unidad nueva....
lexmark x340 toner cartridges needs a chip, that it makes reference you put a new unit toner...
intenta conseguir un chip nuevo y pegalo en la parte posterior de tu cartucho de toner...
try to get a new chip and paste in the new toner cartridge
eso deberia solucionar el problema....
that showld solucionate the problem...
sorry for my solution in spanish, but my english is not god.... good luck!!!!
I had the same problem today with my printer. All of a sudden, the first and fourth light lit up. I contacted Lexmark and they said my toner cartrigde needed to be replaced.
The problem is caused by the little chip under the cartridge. I replaced the chip with an old one I had on another cartridge and I got the printer to work again.
You can buy a replacement chip from Lexmark or from a jobber selling replacement cartridge or toner refills.
Hope that helps.
