Re: How to increase my cell ring volume of nokia 3110c.
Hi anand8055,
While facing your Cellphone there is a button of upper right side of you cellphone. This buttons is Volume up and Volume down. Hope this helps
If its not working try going to "MENU" choose "Settings", then tone. look for a "ringing volume" most nokia have 1 to 5 ringing levelsIf its not working try going to "MENU" choose "Settings", then tone. look for a "ringing volume" most nokia have 1 to 5 ringing levels
You can't post conmments that contain an email address.
What kind of volume you want to increase, you have not mentioned! well, as a suggestion, if you want to increase your volume while listening music, you can take help of buttons present in left or right side of your mobile. or, if you want to increase you ringing alert sound then just go to profile, from their choose a correct option to increase the volume of your ringing alert tone.
Dear Sir .
Currently your mobile ringing tone is set at low ringing volume level.Thats why you are facing this problem.To increase your ring tone sound follow these step :
Select Menu > Settings > Tone settings and from the available
options:
Select Ringing volume . Set Ringing volume to level 2 or above, your phone rings with the volume ascending from level 1 to the level for incoming calls.
I hope this will works for you.
Regards.
Rizwan.
go to menu > settings > personal > profiles > {tap on profile you want to increase volume} > personalise > {select Ringing volume and set Ringing type - Ringing}
There are 2 types of volume in your nokia phone that you can increase or decrease.
The first one is the ring tone volume. You can either increase or decrease your ring tone volume by pressing the menu key then go to settings, go to profile, select any desired profile go to personalise go to ringing volume, then increase or decrease by using the navigation button to the right or left.
The second way is to increase or decrease the volume of the speaker of your phone which i think is the cause of your question (this volume enables you to hear clear and loud the person on the other phone). You increase or decrease the volume by making a call, as soon as the call starts ringing, press the navigation key to right to increase the volume or to the left to decrease the volume.
Cellphone volume decrease due to following reasons you can resolve if you go through it.
1.If you have recently changed any Cellphone Panel, you have to check whether Ear Volume holes are perfect or not..for new panels it wont have Holes proper make it clear.
2.Remove the Dust between Ear Speaker and Panel.
3.If you wan to Increase Ringer Volume check the Dust and Volume out vent gap is proper or not.
