SOURCE: Jamming paper
The paper pickup rollers might be worn out. They can be restored by rubbing Acetone (use gloves)on them just make sure that the acetone doesn't touch any plastic. There also might be a piece of paper stuck in the printer paper path. It might be out of sight and blocking the paper as it feeds into the printer.
SOURCE: x5150 printer turned; no paper in printer; paper feeder continues
Unplug the printer and then open the front and look at the Rear right side and you should see a small
Tab If it is bent then gently with a pencil or pen push it back and try printing if it still gives you problems then contact Lexmark and if you still have a warranty they will replace it if not then you will have to get a new one.
Best suggestion for a new printer that is almost the same is the Lexmark X3550 printer.
SOURCE: Hi I get this 250.07 paper jam check mp feeder on Lexmark t644
Defaulted the printer.
Check the cable form mp feeder connecto main board.
Check paper flag in placed the sensor.
Timming of mp feeder.
it hard happen to the maun board...
SOURCE: Lexmark 3500-4500; how do you open casing to look
try cleaning the rollers with alchohol it should open from the top
If you need further help, reach me via phone at https://www.6ya.com/expert/david_eb7ea98642566cc6
To "Settings/Registration Table"
You can specify the method for restarting scanning of documents when a paper jam occurs in the feeder.
For information on the optional products required to use this function, see "Optional Products Required for Each Function."
Details of each item are shown below.
[From 1st Page]:
If a paper jam occurs in the feeder, scanning starts again from the first page of the document.
[From Stopped Original]:
If a paper jam occurs in the feeder, scanning starts again from the page of the document scanning was interrupted.
