SOURCE: Replace the optical drive on Acer Aspire m1201
based on the images i've looked on for the Aspire m1201, you don't need to remove the front panel in order to remove the optical drive. if there are screws holding the drive in, remove them and then slide the drive forward. if its held in by sliding latches and not screws, then slide then in which ever direction necessary and then push the drive forward to take it out.
SOURCE: acer aspire 5610 wont boot windows XP
turn on pc enter bios setup select default settings save and restart.have os disk in drive wait for screen display any key to start from cd.press any key to load disk.in options select install windows ( not repair) your system will find existing os ,now you can choose repair or install fresh copy.if you choose to install fresh copy delete partition first and create new partition and format.
SOURCE: acer aspire not booting up
Dear f1at3r1c
Righteo then, you should be starting by resetting your BIOS, and you can do this by removing the outer casing o the PC tower. Once yoiu have done this you then need to find the jumper that clears the CMOS/ BIOS. Now if you are somewhat unsure of what a jumper switch is, it just consists of a smallplatic cap which covers two metal conductive pins on the motherboard. There is usually a pin which is not covered.
Now once you have found the CMOS/ BIOS jumper setting, you will need to first remove the motherboard battery. The battery is nothing more than a glorified watch battery of the CR2032 type, and it will be silver in colour and obviously round in shape (typical cell battery).
Once you have removed the battery, you will need to then clear the CMOS/ BIOS and this is done by moving that jumper switch into the clear position. The pin that is exposed will need to be covered withthe plastic jumper, and the pin on the opposite side will need to be exposed. Leave the jumper in the clear position for about 10-20 seconds or so, and then replace it back to the original position. (doing this discharges all of the electricity in the BIOS/ CMOS chip). Once you have done this, you put the battery back in place and then start the machine, then you are good to go. Start the machine and enter the BIOS as you planned to do. You might want to consider ormatting your hard disk and re-installing windows or whatever operating system you have, and this is eeasy enough, just change the boot sequence to boot from your CD/ DVD drive first, the your hard drive second. Once its loaded up, re-enter the BIOS and reset it back to HDD first.
Now f this has not worked, then you have an oooopsie (this is my saying of oh ***T, oops, something has malfunctioned. Its more than likely to be hardware driven, so take out your hard drive first and try to boot, if it lets you bios, then you found your fault. Try this with all devices until you either find the fault, or you have narrowed this to your processor/ motherboard.
Now im sure this will solve your problem, but there is one thng you should need to know about, and it is how to identify the correct jumper. This will have either any of the following markings written on the motherboard very close to the where the jumper is. You may need glasses/ magnifyer lens in order to read the lettering, but it should say one of the following things.
CLRCMOS
CLCMOS
CLRBIOS
CMOSRST
RESET
CMOSRT
BIOSRST
CMOSCLR
CLEAR
could also be under J1, JUMPER1
Now im sure that this is the fixya for you, but if this still does not work, then please get hold of me, and i will provide you with more info.
I wish you all the best, and hope you manage to solve this issue sortly
kind regards
yours sincerely
Oz
SOURCE: Acer aspire l100
This is THE single most common problem with the Acer Aspire L100. Initially really happy with it, but then after five months, mine started freezing and then refusing to boot. Since then it's been very tetchy so I just bought a new computer. The problem lies in the design, it's TOO small to allow adequate ventilation to all the components - something Acer should have figured out before selling the machine. If you can boot your machine up to bios, go into it and change the temperature settings so it runs the fan at full blast. This may help, but I cant garantee it, sorry! If your warranty is valid, demand a refund.
SOURCE: Boot sequence / bios password issues with Acer Aspire 5100
The finger print bull is how that password came up for me and they want a 125.00 to remove it. I called the better business bureau and filed a complaint. They shouldn't have any right to control your laptop. I to have a 6292 , took it apart as far as I could and could not find jumper or password. This is a gimmick to make money.
Anyone know how to fix this please?
