That's a bargain if it works. Apparently the date is hidden in the last three digits of the serial number, so February 1998 seems likely. The only sure way is to contact Hobart themselves. They have a great service department. I have used many Hobart mixers in my catering career.
I found this;
As the previous poster mentions, you can't decipher Hobart serial or ML numbers. I have about 30 pieces of Hobart equipment ranging from mixers to slicers to reach-ins to dishwashers and I couldn't make heads or tails of the numbers. Finally, I got hold of someone at Hobart who I emailed all the model numbers, serial numbers and ML numbers to and they emailed me back the month and year of manufacture. Even after I got the information, I still couldn't figure out where in the serial and ML numbers the manufacture dates were buried.
There is a lever that is riveted to the shaft that controls the movement of the diving key. It may be broken. Email me and let me know what you found. [email protected]
Fist look and check the contact tip. ensure the tip is the correct size for the wire being used as well as the wire feed rollers. the contact tip is were the wire collects the power,
If it's only 3 day's old send it back, dont star strippin it down or you Garantee will be made invalid.
ken
goto this site http://www.hobartcorp.com/default.aspx. you will find a parts list/view. before ordering any parts i would call your local hobart branch because the part numbers have changed.make sure you have the ml number or spec number found on the data plate before hand so youll get the right part numbers.any questions let me know,i repair alot of these mixers im a hobart service tech.
hi i work for hobart and these part numbers dont sound right.you have to make sure you have the ml number or spec number to get the correct parts.you can call your local hobart branch and they will help you further.
