GE Spacemaker JVM1640SJ Microwave Oven Logo
Posted on Aug 03, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a GE spacemaker microwave oven model JVM 1440. A bulb blew and when I went to change both over the stove bulbs stay on all the time. What is the problem and what should I do.
Anonymous
Level 2:
New Friend:
  • Expert 185 Answers
  • Posted on Aug 04, 2011
Anonymous
Expert
Level 2:
New Friend:
Answers
185
Questions
0
Helped
76381
Points
345
There is some kind of circuit board damage. carefully check for burned foil paths on board; around where the relays are. if so, you may be able to "bridge" the broken foil paths with solder. just unscrew the bulbs in the meantime.
1helpful
Relace bulbs ge spacemaker model JVM164OCj02 light that illuminates cooking surface of stove
That model would be JVM1640CJ02.
That is covered on page 33 of your owner's manual.
If for some reason you don't still have yours, you can download it here.
Always be sure you unplug power before you remove or install bulbs in a microwave.
Otherwise you may need circuit board repair.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
GE Spacemaker JVM240WV01 is the model. Both the lights went out. I replaced the light bulbs and they still do not work and the vent fan does not work everything else seems to work fine except for these...
WHEN THE BULBS BLEW THEY PROBABLY BLEW VIOLENTLY AND DAMAGED THE CIRCUIT BOARD THAT CONTROLS THEM MUST EITHER REPAIR THE BOARD BY REPLACING ,REPAIR OR REPLACE THE MAIN TIMER BOARD
Oven is not heating at all. I also smelled burnt plastic. Model is GE Spacemaker XL JVM 1440.
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
1helpful
Light bult in a Microwave oven is burned out.
There should be a panel covering the bulb iside the cookspace with a screw holding it on. Remove screw, cover then bulb.
My GE spacemaker JVM 1440 Watt microwave has F4 error code.
Have GE JVM1440BH light and fan that are operated by the touch pad do not work. Both stop working at the same time. Ideas????
2helpful
Need new light bulb socket for GE spacemaker mircrowave
The bulbs are glued in at the factory. Unplug the microwave and see if you can remove the base of the bulb from the socket with needle nose pliers. You may have to twist the heck out of the bulb base but it should come out. If you do need a new socket it is available at www.geappliances.com under parts and accessories. Or call 1-800-626-2002 for GE factory parts
5answers
GE spacemaker microwave model #JVM1650SH
Allways unplug when your working inside a microwave, you will most likely have to replace the bulb again and also the fan, or anything else that is damaged, you will need to inspect the microwave for broken parts.
Il get you a few links to repair parts.
Top GE Microwave Ovens Experts
vince
NOEL
NOEL
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
