SOURCE: wont pressure up
Most likely your portercable piston ring/seal broke. Its not hard to fix if you are mechanically inclined. See portercable site for rebuild kit.
Check drain plug on bottom of tank, check hose connections on top of tank.
Lugnut61
SOURCE: Leaking sound coming from top
hi buddy the pipe that comes from the pump to the tank connects to a non return valve (pic below) on the tank unscrew the end of this and turn the rubber around inside and try this get back to me if no difference
SOURCE: no air pressure thru quick connect to tools-bag regulator?
I dont know if it is like mine,but if you can let the air out of it and remove the regulator knob,and it`s components,you may can set it to just to be open all the time,in other words,by pass the control knob valve.Shout back at me if I can help.
SOURCE: I have a pancake compressor that won't hold air
If you replaced the head gasket then its probably the valve plate and gasket.
See here:
http://www.chasdayco.com/mm5/breaks/PorterCable/20041110144417_A08610-E.pdf
