The beeping indicates to me that the clock has power to it and it's the problem and needs to be replaced. ya need model number to order part it usually can be found on rim around door or inside of the bottom storage drawer, when ordering parts its call by 4 names, all are the same part its either clock, eoc,oven control,or relay board
Gene
The problem is almost certainly on the control panel, which we repair nationwide for $39.95 postpaid.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This often can affect the exhaust fan operation, too. The lights and fan can be inopoerable or stuck on.
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and
disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
