This question is one of my most frequent on FixYa.
There is no "region-free" or "region 0" setting for any DVD player/recorder. Only DVD media can be region free. Every single offer to set a player or recorder to region free that I am familiar with has been a scam. The reason for this is to prevent DVD piracy.
Most DVD players and recorders (SONY included) have provisions for making a maximum of THREE changes to their region code. A fourth attempt at changing the region code will result in the player/recorder being turned into a paperweight.
Bkhopkins- in your case, you will be able to change your region code from region 1 (USA) to region 4 (AUS). Doing so will leave your player with 2 more changes, maximum. Check your manual for the procedure and the exact number of changes you are allowed. Please be aware that after you change to Region 4, any Region 1 DVD's will not be viewable unless you switch back, which will use another of your three changes.
You have an alternative to salvage your DVD's by downloading a program called DVD Shrink. This program is capable of removing the region code from your DVDs and saving them as region-free at the sacrifice of some quality. You will at least the be able to view your US DVD's without sacrificing a region code change on your player.
Most DVD players have what u call region codes to play different types of dvd's. Look in your DVD menu settings and select the correct region code where u live. The US region code is 1. So this where I would start.
My question to you is does it play normal dvd's ok. Such as DVD's made in the United States, if so it's set right now for US region.
Also check your user maual for all region codes its usually there.
1. Switch on the player 2; open the CD compartment 3. Enter the following code (using the remote): 2812 4. Highlight the region 5. Change to 9 (for Multi-region) using the 'Enter' button 6. Hit 'Clear' to exit
The unlock method should work for DVD players bought in regions 1 (USA) and 3 (south East Asia)
You need to use a One4All Universal remote for regions 1 & 3
1. Switch on the player 2. Pop open the CD compartment 3. Enter the following code (using the remote): 2812 4. Highlight the region 5. Change to 9 (for Multi-region) using the 'Enter' button 6. Hit 'Clear' to exit
