I replaced all bad caps so suspect back light. Is there any wat to test them? Ohms, Scope, external power source??
Thanks, George
Hello
I am a technician-informatic. I have repaired about 80 Lcd Samsung monitors with theese problems. I offer the repair manual.
Manual has been done with the experience of the repairing Samsung Lcd monitors. Manual was made by me and shows how to open monitor, how
to solve dark screen problem, how to check and replace capacitors, how to solve the problem non-optimal mode (without reprogramming MCU or
changing the main board) photo are included. 100% functional. The repair process is very simple 30-40min. (does not need a lot of
experience in electronics and expensive instruments) and is not expensive. With this manual you can solve problems by yourself and save
money.
"Not Optimum Mode 1280x1024 60Hz"
- The monitor turns on but turns off by itself, the LED blinks green.
- If you detach from the PC points to "control cable" the picture runs continuously in the vertical direction or presents while line , and
as soon as it is reconnected, the monitor goes off.
- The monitor does not turns on and dont dispaly anything, the LED blinks green-lit, if you detach from pc points to "control cable".
- The monitor turns on, works well some time, but after a window apiers "Not optimum mode. Mode recommended 1280X1024 60Hz"
- The monitor turns on, works well only with low resolution 800x600, when try to change a window that reads "Not optimum mode. Mode
the manual you can find on ebay (my ebay name is asnerejas123):
Samsung monitor repair manual guide 710n,913v,510n more
220498646211
Riparazione - repair Lcd Samsung monitor 710n,913v,510n
220498645860
Reparaturhandbuch für Samsung 710n,913v,510n und andere
220499443698
The fault is the backlight, Samsung has designed it as when one of the baklights are faulty the unit shuts down.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed SAMSUNG Monitors and bad caps pictures: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Please post back what you find.
We are having the same problem. It started out with the screen coming on dim and flickering and is now to the point where it refuses to come on even if I turn it on & off several times (with a 10-30 sec. pause) and then after being left alone for and hour or so suddenly comes on like nothing ever happened. Must be gremlins!!!!!!!!!!
seem i had same problem with 5 display (214T 21.3"), did enyone know solution for this issue or is this quality proplem of Samsung
BR miika
I have the exact same problem!
its the microchips NT68F63L on vga board. you need to open monitor to solve the problem. there are more than 3 ways how to repair. Can you open the monitor?
or
if you want there is manual how to repair samsung monitors with this problem you can find on ebay: Repair manual Samsung monitor 710n, 913v, 510n and more, Item number: 220389041052.
it shows step by step reparation process.
