This is an internal leak in the gear box, if there has been no oil leakage there is no value in topping the unit up, you could check the disc brake on the side of the gearbox is not binding, it is adjustable with a 1/2 spanner, if all else fails it is a new unit or a rebuild with new centre section kit.
SOURCE: YTH200 TWIN HYDROSTATIC TANSMISSION OVERHEATING
call the manufacture for warrenty work if this is still new
SOURCE: Transmission leaking fluid
I am having the same exact problem. If you do get an answer, please relay it to me. [email protected]
SOURCE: I have a jd LTR
Anything for a Deere is going to be expensive, here is the procedure and it not all that hard, just keep track of parts and tools, Tim :
https://jdparts.deere.com/partsmkt/document/english/featbene/fb_MaintSheet_LT166_48CdeckLawnTractor.pdf
here is info on the tractor:
http://www.weekendfreedommachines.com/gallery/main.php?g2_itemId=89100
maintenance info:
SOURCE: i need a drive belt dagram for a husqvarna yth2348 hydrostatic
Looking at the IPL(exploded parts list) will give you a good look at the route of the belt. Here is a link to use and find your model
http://www.husqvarna.com/us/support/download-manuals/?query=yth2348&types=I&brands=
