I can not install OfficeSuite. I have Windows Vista home Premium. I had downloaded updates all afternoon and it still shows error 1719 Window installer not correctly installed. Help!
  • 304 Answers
Download:Windows Vista Service Pack 1
I tried personally in WIN-XP worked same applies to Vista.
Error Message:
Error 1719. The Windows Installer Service could not be accessed. You may be running in safe mode or Windows Installer may not be correctly installed. Translation:
This message might appear when you’re trying to add or remove a program that installs via a Windows Installer MSI (Microsoft Software Installation) package file. The Windows Installer Service is the standard method for installing and uninstalling software on Windows XP. It keeps track of all of the components that need to be installed for a particular program to run and ensures that any files that are shared by programs are not removed when one of those programs is uninstalled. The Error 1719 is an indication that some Windows Installer Service files are missing or have become damaged. Solution:
The first thing to try is re-registering Windows Installer in the Windows registry. Make sure that no other programs are running and then click Start, Run, type msiexec /unregister in the Open field, and click OK. Next, click Start, Run, type misexec /regserver in the Open field, and click OK. Restart your computer and try installing or uninstalling again.
If you’re still getting the error message, the next step is to try reinstalling the Windows Installer files. In order to do this, you’ll first need to rename the existing files.
First, click Start, Run, and type msiexec /unregister in the Open field, and click OK.
In My Computer, click Search and locate the following three files: msi.dll, msiexec.exe, and msihnd.dll. They are hidden files so you’ll need to select Search Hidden Files And Folders under More Advanced Options. When you’ve found the files, rename them, by removing the .dll and .exe extensions and replacing them with an .old extension(for example msi.dll becomes msi.old).
Once you’ve renamed the files, WinXP will automatically replace them with a new copy from the dllcache (a hidden folder where copies of important system files are kept in case you mistakenly delete or rename critical system files). Restart your computer and try to install or uninstall the program again.
Finally, if neither of the above processes corrects the problem, boot into Safe Mode, and go through the above steps again, first re-registering and then reinstalling.
or
Go through the following links:
http://www.vistax64.com/vista-general/45784-windows-vista-error-1719-help-3.html
Hope this will be helpfull
Please rate me...
Thanks & Regards.
Nandu
Posted on Sep 02, 2008
6ya staff
SOURCE:
I cant download the kb9484865
http://windows.microsoft.com/en-in/windows/windows-help#windows=windows-vista
Check above!
BUT HAVE THE LATEST UPDATED ANTIVIRUS & SECURITY PROGRAM ON YOUR PC BEFORE VISITING ANY LINKs.
May 01, 2014 | Microsoft Windows Vista Home Premium...
Error code 643
Try this for starters:
http://support.microsoft.com/kb/923100/
Basically, it involves un-installing .NET Framework Version 1.1 Service pack
1.
Then download and use (Run as Administrator) the Windows Installer CleanUp
Utility, and remove all references to .NET Framework Version 1.1 Service
pack 1 (only!).
Then reinstall .NET Framework Version 1.1 Service pack 1:
http://www.microsoft.com/downloads/detai…
Then run Windows Update again, to install KB929729.
Jun 25, 2010 | Microsoft Windows Vista Home Premium with...
How to fix error code 646 microsoft windows vista home premium software
* The solution, in a nutshell, is to disable your firewall. If you’re using McAfee Personal Firewall Plus, F-Secure Internet Security, Norton Internet Security or another Firewall vendor, see its respective support page for assistance in disabling it (temporarily). If you’re using the built-in Vista Firewall, keep reading.
* Open the Control Panel and select Security.
* Select Turn Windows Firewall on or off.
* Select Off (not recommended), click Apply and then OK.
* Back at the Windows Update screen, click the Try again button.
* The download(s) and installation should start…
* and this time successfully install. If a restart is required, make sure to re-enable your Firewall once your PC restarts.
* Though this solution will work for most Vista Update errors
Jun 24, 2010 | Microsoft Windows? Vista Home Premium...
An error occured in windows update the page show error in load as it does not that low down internet speed &as no window updation is done
when you update window fist the file activex install
then activex control search which files are not available on your system ,then it listed these files
after that try to down load these files from the web site,
when your system tries to down load these files from web site ,due to lack of proper internet speed,
please contact with your isp provider for increasing internet speed.
if you have any clarification mail me 754030@gmail.com
have a nice day
Feb 15, 2010 | Microsoft Windows Vista Home Premium with...
No Internet Explorer with Vista
You should reinstall Windows vista. But my advice is to update to Windows 7.
Oct 05, 2009 | Microsoft Windows Vista Home Premium...
Cannot download updates
are you using a genuine vista software? Did you turned on the automatic updates?
Aug 23, 2009 | Microsoft Windows Vista Home Premium with...
Update error 8008005
chk this link and download file and run it then prob will solve
http://www.vistaheads.com/forums/windows-vista-home-premium/267173-error-80080005-windows-cannot-update.html
gud luck
Jun 13, 2009 | Computers & Internet
My windows can't check for updates (windows vista home premium). it's showing error code 80244019
Press Win+R, type 'services.msc' and press Enter. Respond to the UAC prompt. Check that Background Intelligent Transfer Service is started and its startup type is 'Automatic.' (It can also be Automatic (Delayed Start).) If it is not started, right-click on it and select Start. Scroll down to Windows Update to make sure that it is started and it startup type is 'Automatic' or 'Automatic (Delayed Start).' If it is not started, right-click on it and select Start. If you had to start either service, try to run Windows Update again by clicking on Start -> All Programs -> Windows Update.
Apr 14, 2009 | Microsoft Windows? Vista Home Premium...
WINDOWS UPDATE WILL NOT WORK IN WINDOWS VISTA HOME PREMIUM
Hey try to do this now
1: Open up "Control Panel" and navigate your way to "Programs and Features".
2: Click "View installed updates" on the left hand side.
3: Find the update KB929777 and uninstall it.
4: Attempt to install the update again in Windows Update
5: Once successful, restart your PC.
and if it works thats good but if it ddnt let me know plz
Dec 02, 2008 | Microsoft Windows Vista Home Premium with...
Computers & Internet Logo
130 people viewed this question
Ekse
Marvin
Marvin
