When I turn the camera on the lens comes out but the red light goes on. If i try to take a picture the camera turns itself off but doesn't retract the lens.
Force it out like it was forced in. Try to rotate the lens. Remember it has to be off. As soon as the lens is half way out, turn the camara on and the lens will go to its position. If not, while the lens is out turn it left or right until it's back to its position. Good luck.
I'm curious....the camera came out in 2006....how did you buy a second one?...and more importantly, why? If something doesn't work, the first thing people do isn't to go out and buy another one. Anyway, from your description, the problem seems to lie with the cards, not the camera. All memory cards must be formatted (sometimes called "initialized") in the camera before use and regularly after downloading the pics to the computer. This erases the card and brings it back to original condition so download any pics you want to save using a separate cardreader if necessary and then, format/initialize them in the camera.Also, how old are these cards?....they don't last forever.
1. Try cleaning the battery contacts inside the battery compartment.
2. Try removing the media card, then turn on camera. If its ok, then you have a bad media card, try formatting the media card.
Unfortunately, many cameras that fall prey to lens error problems can only be corrected by professional repair. But, here are some last resort troubleshooting steps that you can try that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try.
By the way, I also own an A620, great camera! Hope you have luck with the above.
Sounds like the battery might be low which would cause the red flashing light and dark screen. Let it charge for a little bit then try turning it on again. If it still does it with the power supply plugged in, make sure there isn't a lens cover on it, and switch modes or try getting into the menu to see if you can get anything to come up. If that still doesn't work then it sounds like there might be a problem with the camera.
I have the similar problem, I turn on the camera and after the lens comes out , red light blink all this time, and suddenly it powers down without retracting the lens back in.
The battery are fully charged AA 2400mah / 2650mah Duracell at 4.0 ma with load test. I was wondering if there is any circuitry problem.? Any experts in digital camera electronics please respond?
Trick:
To bring back the lens back in for safekeeping i trik this, i turn it on while it is reading the memory etc and after a sec or two i turn the knob to off, this way lens goes back inside.
I have read other brands also have their cameras lens sticking out and never going back inside.
