SOURCE: Tone arm moves to the middle rather than the beginning
There is 33and 45. that's the size of the record.There should be a level to change from one to the other.
SOURCE: won't start
I had the same problem with the arm constantly starting and stopping, and the suggestion above works. Despite, I was a little confused on how to do it. Here's what I did in detail:
- Remove the turntable mat.
- Unhook the belt and remove the turntable platter.
- Once the platter's removed, you should see two plastic white gears in the middle. Rotate the center gear clockwise until its tab hits the larger gear. The center gear should move freely and without resistance until you hit that gear.
- Put the platter back, making sure to re-hook the belt around the spindle.
- Put the mat back.
After that, you should be set!
SOURCE: tone arm comes out and touches record, then goes back to cradle
See what kind of arm position sensing elements are used in your turntable (micro switches, optics or possibly other) and check if they work correctly - sometimes a microswitch can be damaged or have oxydized internal contacts or a badly soldered / broken wire and it will not function properly, causing the unit to stop automatically, the same might happen if the sensor is of optical type and there is some dust or broken wires or if the emmiter or sensor is damaged. Also, it could be a problem with the part that activates the switch / optics, it might be displaced or damaged.
If all sensors / switches seem to work well, then check the section which has wires going to those sensors / switches, it's the next probable location of the fault (it might be an electronic controller so there could be damage to some components, broken wires, dirty connectors or bad solder contacts).
It could as well be something else in the mechanisms, wiring or electronics, i just suggested a few things that might cause the malfunction you described.
Hope you can get it fixed.
regards
3rq8 (Triarcuate)
SOURCE: when i press start, the record spins and the arm
Is this a belt driven one? If it is then try replacing the belt
