SOURCE: Minn Kota electric motor MKJI1033962
Best to call Minn Kota direct for the manual Youll need your serial number thrust of motor and shaft length..
800-227-6433 they will help you with any technical questions.
Parts can be purchased from this dealer...There are schematics on the site for review....
http://www.northlandmarine.com/MinnKotaQuickRef.htm
=100){IAjax.Pop('/WorkArea/showcontent.aspx?id='+id);}else{__LoadTaxonomy(IAjax.getArguements(),'pagerequest=showcontent&__ecmid='+id+'&control=ctl00_ctl00_ctl00_skin_body_variant_body_nav_body_Directory1&__ecmdiv='+tag);}}function OnDirectoryItemBubble(id,width,event){__LoadTaxonomy(IAjax.getArguements(),'pagerequest=bubble&__ecmid='+id+'&control=ctl00_ctl00_ctl00_skin_body_variant_body_nav_body_Directory1&bubblewidth='+width+'&X='+EBubble.EventX(event)+'&Y='+EBubble.EventY(event));}
function DmsMenuInit(){ dmsDynamicContentBox = false; dmsCommunityDocuments = false; }function OnAddCategory(name, selectedTreeId, parentId, action, id, type, share){__LoadTaxonomy(IAjax.getArguements(),'pagerequest=addworkspacecategory&__categoryname='+name+'&control=ctl00_ctl00_ctl00_skin_body_variant_body_nav_body_Directory1&__selectedTreeId='+selectedTreeId+'&__folderId='+parentId+'&__action='+action+'&__taxonomyId='+id+'&type='+type+'&share='+share);}ektj$(document).ready(function(){DmsMenuInit();}); // -->
.EkTB_overlayMacFFBGHack {background: url(/WorkArea/images/application/macFFBgHack.png) repeat;}
SOURCE: How do you program extra Minn Kota® CoPilot Replacement Transmitters?
According to my user manual
To learn the ID number of additional remotes, follow these steps:
1.) Press and hold the LEARN button located on the side of the receiver (receiver will emit a continuous tone). A small blunt object must be used to depress the LEARN button (pen or screwdriver).
1.) Press any button on the remote (receiver will beep 4 times confirming that it has "learned" the ID number of the remote and that the programming is valid and complete).
SOURCE: Minn Kota 54lb hooked up backwards (Pos. to Neg) wont work
Unfortunately, those units have a circut board at the power source and if there is no fuse you more than likely destroyed that board. Take the casing apart (the part attached to the boat) it should be two halves. That inital board you see is probably what is destroyed. Of course before i did that I would look for an inline fuse near where the cables attach to the battery or under the unit in the nose of the boat. There is nearly always a fuse if it came from the factory or dealership with the unit so i'd play a little extra hide and go seek for that before doing anything else.
Best of Luck
