Question about Canon PowerShot SD400 / IXUS 50 Digital Camera
Can not format new card, not sure why this is happening?
    Brigadier General:
  • 3,006 Answers
Have you used the correct card?
It's very common for users to try too large a capacity or even the later SDHC cards which were designed long after your PowerShot SD400 / Digital Ixus 50. That camera can only accept SD cards to a maximum 2GB capacity, and with some brands it's a bit fussy and will only accept 1GB.
Also note that your camera does not need high speed SD cards, if you put an advanced speedy model in there it will work (subject to the previous restrictions) but your camera lacks the ability to make use of the speed.
Posted on Aug 02, 2011
Anonymous
SOURCE:
Initialization Error on my nikon d40
Not sure how you are downloading the pictures to the computer but starting from scratch check the SD card to make sure the lock is in the "open" position here is a diagram for that. It doesn't matter that it has Kodak on it, I took this as a screen shot and wrote on it to show the unlock position of that annoying little switch. see more below diagram
Make sure the pictures have been downloaded to the computer at this point as the lock would have prevented this from happening. Now what you need to do is format the card not delete format. The manual I have is a reference check your manual for this procedure. Formatting should be done each time you download pictures to the computer, new memory cards or taking one memory card from one camera and putting it in another. Format, Format and yes format Cheers for now
Jan 07, 2011 | Nikon D40 Digital Camera with G-II 18-55mm...
I have put a new sd card in my camera,and its says memory is full. What could be wrong.
A few things can be happening first the SD card may have the lock switch in the lock position I'm including a diagram to show the correct positioning.
The next thing is you said you put a new SD card in. All memory cards need to be formatted to the camera they are going to be used in formatting cleans the card (yes I know it's new) and makes it compatible to the camera. Also each time you download pictures to the computer the memory card needs to be formatted to re clean the memory card and make it ready to accept new pictures. One other thing your camera has a small capacity in todays standards and the largest SD card I see being used is a 256mb, if the new card is larger then 256mb this could be the problem as well. If this is the case then it might be possible to update the camera firmware. However it would be a whole lot easier to purchase a 256mb card. Format the new card making sure the lock is in the right position and continue on as you have been.
Jan 05, 2011 | Kodak EasyShare C330 Digital Camera
After inserting the new SanDisk, SDHC Card, 8GB the camera prompts "Memory card requires formatting", press continue; warms that formatting will delete everything on memory card; pres continue;...
First thing; check owner's manual and USA distributor, make absolutely sure that this camera is able to read/write to a 8GB card!
If so, put that card into your computer, directly into appropriate slot or through a "reader" and the USB port. If computer runs Windows, access My Computer, click on external memory device, and RIGHT CLICK. You will get a box which offers to format the card. You can rename the card at the same time. The computer's format routine is stronger that the one in the camera. If problem still happens, consult distributor. May be fixable with a cable from camera to USB port, you download new software from distributor. Follow their instructions EXACTLY.
May 14, 2010 | Kodak EasyShare Z650 Digital Camera
Sd memory card says card can not be read why?
you can try formatting the disk. otherwise, it may be erased or damaged.
this same thing happened to me with my sandisk 8gb micro sd in my phone.
I lost everything on the disk, it never worked again , and still not sure how it happened?
maybe they zap em from satellite to make us buy new ones? LOL who knows.
more than likely if it cannot be formatted and cannot be read it's done.
p.s. did you check to see if the disk is locked?
Mar 26, 2010 | SanDisk 1GB microSD Memory Card
Hi: I have a lumix/Panasonic DMC-FS3. I keep getting a message "Memory Card Error. Please check the card." Nothing has happened to the card. What could cause that?
Has the memory card ever worked in this camera? If yes, try downloading all the pictures to your computer then format the memory card using the camera setip menu. If this is a new camera, Make sure the camera can use the SD HC type memory cards. Some older cameras cannot read the SDHC but are fine with the SD cards.
Nov 21, 2009 | Panasonic Lumix DMC-FZ20 Digital Camera
I have a Kodak easyshare LS443 and when I put in a new picture memory card (bought two of them already), after it says 'format memory card' and I do, it just keeps saying 'reading memory card' and nothing...
Make sure that the memory card you used is compatible w/ your camera. If same issue persists after using the compatible card, camera is unable to detect the memory card. Card compartment is defective. call 1.800.235.6325 for repair.
Thanks.
Neerak21
Sep 25, 2009 | Kodak EasyShare C875 Digital Camera
I have a scandisk sdhc 8gb memory card for my digital camera and I had tried to erase all photos from it so afterwards it says 'MEMORY FULL' but there is nothing on the card to my knowledge I even stuck it...
Sometimes this happens. Sometimes the speed rating on the memory card doesn't match your camera. Most people think all SD cards are the same. I assume you have the right card, but if you're unsure, then be sure to check to be sure. Another problem is that if someone tries to format the card in something other than your camera, it messes up the format on the card and it becomes incompatible with your camera. Sometimes you get a bad card that the retailer recycled because it was a return or maybe someone sold it to you on eBay. These problems happen. You will have to get a new card and make sure everything else it alright with your camera and card reader.
Sep 12, 2009 | Samsung NV3 Digital Camera
Was OK, but now memory card requires formatting? Kodak Easy Share C-530. I tried several times to put in new memory card, but it always says it needs reformatting and when i try "continue" it then goes to:...
She is not arguing with the camera. Sheesh. When she says she hits "continue" she is talking about continue for the camera to format the card. But instead of formating the card it says filesystem error e00100. The camera will NOT format the card. I have the same problem. I can format the card on the computer, but again the camera says it can not read the card and needs to format. You choose to format, and it says filesystem error e00100. My card is brand new. So I used cards I have owned for while and used in other cameras. Same thing happens. I tried 4 different cards. A 4gb SDHC, thought that format was not compatible so switched to a regular SD 2gb. Same thing happened. Also tried Standard SD 16mb & 128 mb. All do the same thing.
Jul 21, 2009 | Kodak EasyShare C315 Digital Camera
Nikon coolpix 4600
Have you formatted the card? When you buy a new card for a camera it may have to be formatted by the camera so it can be used. Note: Any data on the card will be lost during the formatting, so make sure you have a backup of any content there.
Sep 01, 2006 | Nikon Coolpix 4600 Digital Camera
Trouble formatting card
Did you happen to write files to one of the cards from the computer, or delete files from the card through the computer before that happened? This problem has been known to happen in such cases. Remember to only *copy* files from the card to the computer using the card reader, and only delete files using the camera. Anyway, try turning off the camera, pulling and re-inserting the card. If it doesn't work - try it a few more times. If it still doesn't work and you've got nothing to lose, try deleting any files you may have written to the card using the computer, and then try again. But the fact that the new card didn't work as well might mean that it won't help. Good luck.
Apr 04, 2006 | Olympus Camedia C-150 Digital Camera
Canon PowerShot SD400 / IXUS 50 Digital Camera Logo
59 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Ekse
Poul Brinchs Larsen
Are you a Canon Camera Expert? Answer questions, earn points and help others
