NEVER CONNECT PEDALS THROUGH THE EFFECT LOOP OF AN AMP. They are NOT design to work at the same signal levels !!! ONLY use effect units that are design to be used in amp effects in the amp effects loop/
Thank you! I really would never have known this. No one tells you this stuff, and manufacturers are only too happy to let you think it will be OK.
I appreciate that, thanks again.
R
For the guitar problem, you need to open up the electronics protion and look for broken soldering of leads in it. Get some CRC226 at Home Depot electrical dept and using the spout put a bit in the volume pots through the slot where the leads go in. Also you can use it on the switch if the contacts are open type. ALWAYS loop your guitar cord through your guitar strap or belt loop to avoid twisting the plug in the guitar and wearing the connection which will cause electrical noise. Also when you have the guitar open see if the leads of one of the volume controls have rotated and may be touching the wall of the cavity they sit in. The paint on the walls of the cavity is normally conductive for sheilding purposes. Now for the amp problem: Leave the amp warming up a couple hours without playing and then see if it fails quickly when you start playing. Common problems are often BROKEN input jacks that have been broken by tripping over cords. When unit fails, try banging on it to see if there might be a broken solder connection... in fact MANY of these breaks are at the leads for volume pots... when failed, try grabbing the knob and moving the knob (without rotating) sideways and up and down... do this for ALL the controls... If you can get itself to show the problem you are halfway there.
The store should have a record of selling your unit by serial number... you may not need the receipt for warranty...
