Question about Whirlpool Freezers
My upright freezer has water coming down from top shelf and creating ice on the drawer fronts
  • 2,341 Answers
In a case like that most likely the door gasket isn't sealing on that corner , a dollor bill placed around door then close it should have some resistiance when pulling it out, if it comes out easily the door gasket needs replacing
Gene
Posted on Aug 01, 2011
6ya staff
SOURCE:
Why is water is gathering and freezing at the front on the bottom shelf of the freezer?
because your drain hole is stopped up clean all of the ice from the area and flush with hot water
Nov 18, 2010 | Woods Upright Freezer V1613RW3
Frost build up especially on top shelf all other shelves except one gets a 3 inch layer of ice in approx 4 months. The freezer is kept in a mod temp basement room and the freezer door is opened less than...
Things you can do to cut down on frost.
1.make sure all seals fit flush to frame.
2.use a thermometer and set freezer to -18c(beef will keep upto 12months).
3.wrap all food as airtight as poss.
3.do not overfill,leave space for air flow through drawers/shelves.
4.defrost every 2/3 months in humid conditions using clorine bleach to clean interior,and dry thoroughly.(leave door open to dissipate clorine gas.)
Aug 18, 2010 | Woods Upright Freezer V1613RW3
We have a Kenmore upright freezer. Ice develops
Sounds like you have a seal system leak.If you have got work done not long ago to the system it my be over charged or under charged.If no work ever done to it you may need a new freezer.
Sep 03, 2009 | Freezers
Admiral upright freezer dripping water inside on top
Hello.
I can help. Once we notice anything different from before we start becoming more aware of small variations. Regarding things on the top shelf warmer than on the bottom, this is always true because, "warm air rises and cold air falls". If you want the top shelf colder turn the thermostat to the next colder setting, always a good idea in the Summer season anyway.
Even though your gasket looks good, a ten year old gasket is not as pliable as a new one resulting in the moisture problem you describe. I would begin by applying a thin coating of vaseline to the gasket once a week for a month. This little trick of the trade will often work. If it doesn't improve the situation do replace the gasket.
Jun 25, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Upright freezer door inside developing ice
The door seal is at fault. Regardless of the small tear it is not sealing well.
Take a dollar bill and close it in the door. Then pull on the bill to feel resistance.
You will find it pulls easily in some place. That is where your air leak is that is causing the condensation.
Do this about every 6 inches all the way around the seal.
Mar 27, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Top & middle shelves COVERED with frost/ice, not middle
That is normal. The refrigerant runs through those shelves. They are the evaporator side of the unit.That is where the freezing effect comes from.
Check door seals for leaking air.
Keep door openings to a minimum.
Get in there and get out.
Those things will help prolong frost/ice buildup.
Mar 12, 2009 | Whirlpool 16.7 cu. ft. / 473 liter Upright...
ICE BUILDUP ON BOTTOM OF FREEZER, DRAIN HOLE FROZEN
There is normally a small filiament of metal which is attached to the defrost element and conducts heat down the drainpipe preventing ice build up. You can pour some boiling water onto this area and even wriggle a piece of plastic tubing down the drain pipe to dislodge any blockage. For future prevention, you can attach a piece of copper wire around the defrost element (in the absence of the original filiament) and extend it down the drainpiple
Mar 05, 2009 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Bottom drawer wall is covered s ice/ top shelf not freezing
Sounds like a defrost system problem. Could be related to defrost timer, heaters or defrost thermostat. Have it serviced.
Jun 09, 2008 | Frigidaire 14.1 cu. ft. Upright Freezer...
FRIGIDAIRE UPRIGHT FREEZER ONLY 2 BOTTOM SHELFS FREEZING
someone suggested to me the other day to put weter foods closer to the top the ones with dripin water and more solids down at bottom they said this changes the climate inside to be more economical
im just passing this info cause ive never had or been in contact with a upright freezer
May 13, 2008 | Frigidaire 14.1 cu. ft. Upright Freezer...
Freezers Logo
85 people viewed this question
Top Whirlpool Freezers Experts
Dennis Boxerman
jasbo
jasbo
Andrew Taylor
Andrew Taylor
Are you a Whirlpool Freezer Expert? Answer questions, earn points and help others
