SOURCE: Hoshizaki Freezer Commercial Ice Machines - KM900MRH
have you checked the bin switch or the float?
SOURCE: hoshizaki condensor fan motor is not working
Too long to explain sequence here. but in the harvest mode the fan will not be running. go to hoshizaki.com you will find every thing you need very helpful site . and a clean machine is a happy machine. hope that helps Tom
Check to be sure the check valve is not leaking by. This will cause reduced capacity as they are controlled from water level. Remove, clean, and re-install the check valve and check its operation.
