Question about Nikon D40 Digital Camera with G-II 18-55mm Lens
Nikon D40 help?!
I have a nikon D40 camera. I was taking pictures with my new puppy and he knocked it over onto the ground and now the automatic focus won't work. It will focus but it will not take a picture and the flash won't pop up. Any help??!!!
  • dclark25 Jan 09, 2009
    My flash has stopped firing and my auto focus will not work either. I don't understand why. Can it be fixed? If so, how much $.
    Sergeant:
    Champion:
  • 435 Answers
I assume the lens had the impact. The 18-55 lens has the built-in motors for auto-focus.
Try switching to manual focus (on the lens). If this works, the lens may not auto-focus anymore.
Try it and let me know.
cheers,
Posted on Sep 21, 2008
6ya staff
SOURCE:
My Nikon D40 won't take pictures!
Your twin sister #&%@ed up your camera.
Jun 07, 2010 | Nikon D40x Digital Camera
Lens issues with Nikon D40 camera
Have you ever cleaned the contacts on the lens and the camera body where they meet? If not, do so now with a cotton swab lightly dampened with rubbing alcohol.
May 03, 2010 | Nikon D40 Digital Camera with G-II 18-55mm...
Ive got the nikon d40. when i take photos close up they are blurred. there r 2 settings on the focus lense one is letter a one letter m. you have to move switch to indicate one or other. camara wont take...
The letters you're referencing is the M/A (manual / auto) focus switch. The lens has this switch and operates in Auto Focus mode when set to "A" and manual focus mode when set to "M".
You have to manually focus on the subject when in letter "M". If you do not, the result will be out of focus. From your description, it sounds like the camera / lens combination is attempting to focus and operate the shutter in auto, and focusing in manual; but due to some type of damage resulting from possible mishandling, exposure to dust, dirt or even moisture is interfering with the successful completion of the process.
You could isolate the problem to determine if the cause is in the lens or camera by simply attaching the lens to another compatible Nikon camera or placing a different auto-focus lens on your D40. The problem will either stay with your D40 or follow the lens when attached to a different camera. It is also *possible* that due to numerous attempts of auto-focusing with your D40 & lens combination, that both the lens *and* the camera have been damaged. If the problem is severe enough, the problem in the failed device could cause failure in the otherwise normally working device, too.
You might be best served by contacting Nikon Service & Support below:
http://www.nikonusa.com/Service-And-Support/Service-And-Repair.page
You also said you lost your manual. You can download the manual for the D40 directly from Nikon in your choice of English, French or Spanish from the link below:
http://support.nikontech.com/app/answers/detail/a_id/14157/session/L3NpZC9YRTgxQVpKag%3D%3D/kw/D40%20manual/p/19%2C334/c/187/r_id/116678/sno/0
Oct 09, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
Nikon auto focus lens not working, only in manual
What camera body? This lens doesn't have an internal focusing motor and thus will not autofocus on the D40/D40x/D60/D5000/D3000.
Sep 10, 2009 | Nikon Normal AF Nikkor 50mm f/1.8D...
The Autofocus does not work on my Nikon D40
1 Possiable dirty lens contact terminals
2 Auto focus motor in lens is jamed/malfuntion
3 Auto focus engagement pin on camera body is not engaging the lens
4 Correct lens,old nikon lens and some 3rd party lens wont work on the D40
Jul 18, 2009 | Cameras
My Nikon D40 18-55mm lens won't work on automatic
THERE is a problem in lens not with the UV filter
remove the lens clean the contact of lens & camera if not working repair or replace it
Jul 17, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
Nikon D40 will not focus when shutter pressed 1/2 down
has the lens stuck up? put it temporarily on 'M" and try to turn the focus ring. this should be freely turning;
otherwise you may want to check the camera body to lens electrical contacts (silver).. a small dab of alcohol to a q-tip.. make sure its not that wet..then try to clean the contacts.
Jan 31, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
Nikon d40
The G series lenses won't work in AF mode on the newer, entry-level Nikons. They require the DX series.
Jan 04, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
Autofocus will not work,
Camera wont let you take a picture until focus is locked, why are you using M (manual focus) if you expect autofocus to do it for you? In M mode it is up to you to focus correctly or camera will not take the picture.
Apr 13, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
Nikon d40 digital camera
When the camera is in auto focus mode, it will not take the picture until it locks onto a subject. If there is not enough light, the camera will "hunt" for something to focus on. Since it can't define any edges, it won't allow the shutter to release.
The D40 base model does NOT have a powered focus lever for autofocus, so if the autofocus is not working, suspect the lens.
Mar 23, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
Nikon D40 Digital Camera with G-II 18-55mm Lens Logo
232 people viewed this question
Top Nikon Cameras Experts
Ric Donato
Ekse
pictureman4u
Are you a Nikon Camera Expert? Answer questions, earn points and help others
