Question about Belkin Basic Wireless Router
Need the ip address for Belkin router setup - Belkin Basic Wireless Router
    Master:
  • Belkin Master
  • 317 Answers
Hello the default IP address for Belkin router is 192.168.2.1. To know all about of Belkin Basic Wireless Router visit here:
How To Login Belkin Wireless Router 192 168 2 1 TechVaidya
Posted on Aug 11, 2018
    Genius:
  • 1,400 Answers
6ya staff
SOURCE:
How to set up a static ip address on a dvr
To access Belkin's web based setup page type 192.168.2.1 on the address bar of the browser.
And if you can follow this web link to setup a static Ip for your DVR , in case if you need further help you can contact me directly ..
http://www.corenetworkz.com/2009/07/setup-belkin-wireless-n-router-by.html
Mar 31, 2012 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Im trying to set this up as an access point. but it will not fine a ip from the router
Most router wont act as a DHCP client (Get an IP address) on their own.
You need to go into the Belkin setup and set it to an IP address in the range of your other router.
For example:
If your PC is getting (connected to the same network) an IP address of 192.168.0.3 IP and a Default Gateway address of 192.168.0.1 you can set the Belkin with any adderss between 192.168.0.10 & 192.168.0.254. Changing the last octet (set of numbers after the 3rd period) to the desired address.
Mar 02, 2011 | Belkin Wireless-N Wireless Router with...
I have a belkin g+ mimo router and am currently trying to set it up as an access point to interact with my d-link dir-615 router. when i add my d-link routers ip address string, the belkin disappears. i...
Hello...
Steps To Convert your Belkin Router as an Access Point.
- Connect your D - Link Router to your PC & Check the Default Gateway It Might Be 192.168.1.1 or 192.168.0.1
( Finding Default Gateway: Right Click on Local Area Connection & click on Status - Click on Details For Win 7 & Win Vista & For Win Xp - Right Click on Local Area Connection & Click on Status, Select Support Tab & Click on Details )
- Now Connect the Belkin router to your Com .. Open Internet Browser & Go to 192.168.2.1
- Towards your Left Corner Under Wireless Clink on Use as Access Point
- It will Prompt you For a Password Leave it Blank & Click on Submit
- Select the Radio Button Next to Enable
- In Specify IP Address Type in IP Address in Range of your D - Link Router Eg: 192.168.0.254
- Select Subnet Mask - 255.255.255.0
- Click on Apply Changes
- Now Open the Router Setup Page Using the Ip Address which you gave EG: 192.168.0.254
- Connect an Ethernet cable From your D - Link Router to Any 1 of the Wired Slots on the Router ( Note: We are using Wired Slot as we have Disabled the NAT on the Belkin Router It Gives you IP Address From your D - Link Router & the DHCP on the Belkin Router is Turned Off)
- Power cycle the D- Link Router & Belkin Router For 15 Seconds Each ( Unplug the Power cable & Plug it Back After 15 Seconds)
- Now go to the Router Setup Page & Check the Internet Status in the Top Right Corner It Would Be Connected.
- Try Going Online... :)
Feb 19, 2011 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Plycom ip330 phone - works fine when connected directly to Brighthouse modem, however when brighthouse modem connected to belkin router then to phone says - waiting for network to initialize, please help
sounds like your belkin router is not setup as a DHCP server or the DHCP is disabled. The DHCP in the belkin assigns addresses to the internal network, the error "waiting for network to initialize" means that the phone is waiting for an IP address, to which its not getting. When you connect directly to your modem you get an IP from your Internet service provider. I'll bet your internal network is setup using "static" ip addresses, if thats the case you will need to surf into the phones web console and set a static IP address. Or the opposite, enable DHCP in the belkin. hope that clarifies things a little.
Aug 28, 2010 | Polycom SoundPoint 330 IP Phone
Belkin Wireless N router/Embarq 660 modem/No internet
Make sure your physical connection is correct. From the modem, the ethernet cable should plugged in to the Internet/WAN port of the router. And your computer to port 1. Access the setup page of the router again and Enable the MAC Address Clone setting. Clone the MAC Address of your PC there then power cycle the router and modem. You should be all set.
Apr 15, 2009 | Belkin (F5D8231-4) Wireless Router...
Belkin wireless router
Your Belkin router is normally configured to get a dynamic IP Add from your Internet provider unless otherwise configured. Most ISP's network where clients/subscribers connect (through DSL) has a DHCP server that hands out this IP adds. If your router keeps on changing its WAN IP add, it may presumably be because:
1. Your router keeps on rebooting or powering on/off and everytime it turns on, it is given a new IP add;
2. Your ISP's DHCP server keeps on renewing its lease on the IP add given to your router.
Corrective measures would entail:
a. Do a full hard reset of your router and go through the installation setup again. Of course this would revert all settings/configuration to factory default; and/or
b. Contact your ISP and explain your concern.
In some cases, the router's MAC address has an issue that the ISP's DHCP is keeping a hard time recognizing it. this can be corrected with a firmware update.
Hope this be of help/idea. Pls post back how things tunrs up or should you need additional information.
Good luck and kin regards.
Feb 03, 2008 | Belkin (F5D7230-4) Router (587009)
IP address
Hi tammyhope,
I would guess that your ISP is providing a dynamic IP address for connectivity to the internet. If your router is changing the IP address back to default, I would think that your configuration is not setup properly, to receive a dynamic address, but is set with a static address instead. So what happens is that when you attempt to connect to your ISP your router is resetting. If this is the case then you need to go into the router configuration and set it to recieve a dynamic address from your ISP.
--RoadHawk
Nov 25, 2007 | Belkin (F5D7230-4) Router (587009)
Belkin Basic Wireless Router Logo
103 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Ekse
Jeffrey Groves
Jeffrey Groves
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
