SOURCE: IBM Netfinity 5600 8664 81Y Server
The disk that comes with the machine is called the NOS in the manual. It is also known as ServerGuide 6.0.3 which will config your Netfinity up to Win2000 Server. I used ServerGuide 7.3.06 to install Windows 2003 Server. The latest version (IBM ServerGuide Setup and Installation CD v7.4.17) is on the support IBM web site:
http://tinyurl.com/5fmv5k
SOURCE: server doesnt boot
First create a floppy disk with your RAID driver for W2K3 Server. Next boot the server with the W2K3 Server CD, and hit F6 when prompted, and S to add the specific driver for your RAID and using the floppy to get the driver installed.
Next boot to the recovery console of W2K3 Server. If it finds your hard disk, it will even ask for your Administrator's Password to continue. If this works, then you are probably home free.
Get to the command line of the W2K3 Server Repair console and perform some directory searches to see if the data is there and intact. You can also perform a CHKDSK from that console.
Once you have made sure your data is there and intact, type these two commands: FIXMBR and FIXBOOT
This should solve the problem and when you EXIT out of the console, it should reboot. Remove the CD and it "should" re-boot from the hard disk.
If you still have problems, let me know with how far you got with the steps above. I have another solution but need to know your RAID controller's model (ServeRAID 5i, 6i, etc).
-Chip
SOURCE: In IBM x236 server, one swap drive amber led is blinking
Please check how the disks are configured?
If mirrored and second mirror is avaliable you can
replace the disk. (It is the same if the raid5 configured.)
You can download the Hardware Maintenance manual from ibm to
help you in the disk replacement process:
ftp://ftp.software.ibm.com/systems/support/system_x_pdf/25k8114.pdf
SOURCE: About ibm server x3400 drivers
You can download the drivers from IBM's website:
http://www.ibm.com/support/us/en/
