SanDisk Sansa e250 MP3 Player Logo
Posted on Aug 01, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Loaded 8 g sd card but can not locate the songs when I try to play?
Level 3:
One Above All:
The expert with highest point at the last day of the past 12 weeks.
Top Expert:
  • SanDisk Master 102,366 Answers
  • Posted on Aug 01, 2011
SanDisk Master
Level 3:
One Above All:
Top Expert:
Answers
102366
Questions
0
Helped
10442366
Points
622693
The e250 works with microSD cards, which are limited to 2GB. Your 8GB card is actually a microSDHC card. While it fits into the slot it is electronically incompatible and will not work. More recent Sansa players accept microSDHC cards, but this model is limited to cards 2GB and smaller.
Sorry if that wasn't the answer you wanted to see, but that's the way it is.
MUSIC I MOVED FROM COMPUTER TO SD CARD WILL NOT PLAY ON CELVIANO AP620 PIANO
http://support.casio.com/pdf/008/AP620_6_E_1A_web.pdf
E-48
Using a Memory Card
You can use the procedure below to play back a user
song (page E-24) stored on
a memory card without
loading the song into Digital Piano memory.
Memory Card Folders
Formatting a memory card on the Digital Piano will
automatically create the four
folders shown below. You
put playback song data into any one of the folders. You
can use the four folders to group your music data by
family member, genre, or some other categories. Use
buttons
through (folders) to select a folder.
1.Store the music data you want to play back in
one of the memory card folders.
2.Insert the memory ca
rd into the Digital
Piano's memory card slot.
3.Press the (CARD/INTERNAL) button.
4.Press one of the folder selection buttons (
through
) to select the card folder you want.
This will display the song number and song
name of the first song in the folder you
selected.
5.Use the (w,q) buttons to select the
song you want.
6.Press the (PLAY/STOP
) button.This will start playback.
•Each press of (PLAY/STOP) starts and stops
playback.
•Fast forward, fast reverse,
tempo changes, and other
operations are the same as
those during playback of a
user song in Digital Pian
o memory. For details, see
"Playing Back a Specific
Music Library Song" (page
E-24).
7.
To quit memory card data playback, press the
I cannot transfer music from micro sd to my kyocera phone
You should not need to transfer the music from the sd card to the phones memory, but play the songs directly from the sd card. Once the songs are loaded onto the sc card in the right format, (MP3) your phone should find them on the card.
My H2O man doesn't seem to read the card my songs are loaded on. I converted the files to MP3, but it still doesn't play. The blue light blinks fast then turns red.
If the player blinks blue really fast then red it can only be one of two things.
One: The bracket that goes over the micro SD card is not slide up and locked into place once the card is inserted or
Two: One of the songs loaded on the micro SD card is in the incorrect format. Try playing just the songs that came on the player first. If thoughs work then load 10 new ones on and see if they work. Keep gradually adding songs until the player stops working to help find the problem song.
If you have further questions please call Intova at (808) 837-0074 or e-mail [email protected]
Thanks,
Intova
Play back music from sd card
If the music is loaded correctly, all you have to do is the hit the music button and select either "All Songs" or "Shuffle". The phone automatically loads songs on the SD cards.
Garmin nuvi 360 can't read sd card
Make sure you format first the sd card and then the maximum giga byte is 2 mb and the minimum is 16 mb.
I’m happy to assist further over the phone at https://www.6ya.com/expert/ramy_d9e7ebea3891f482
5helpful
2answers
I dont know how to put music in the sd card
To add music to your DSi, first you need a spare sd card, and a pc or laptop that can sync with the card. Remember that the DSi only plays AAC type songs, so convert the songs you want to copy-paste on the card. This can be done easily on Itunes on which I use by right-clicking on the song and it will show you there ' convernt to AAC'. After saving the songs , take out the card from the pc or laptop and you can now insert the card in your DSi and play music and enjoy.
2GB SD Card Problem.
you cant expect all mp3 players to play as many songs as u wnt. each mp3 player has a limit of memory card that needs to be attached. see whats the maximum memory your mp3 player can support. and also see if you can locate all the songs when the SD card is connected to your computer
2helpful
3answers
Playing mp3 songs on the ps3 --- 80gb
Whether you are hooking up your device through a USB cable or removable memory (SD card/Flash drive) the PS3 should recognize and play the titles. Here are a few steps to help you along.
1. Hook up device to your PS3
2. Select PS3 media icon where files files should be located
3. Press triangle button on controller
4. Sub menu will show up on side of screen
5. Select the 'display all' option
6. Files should now be accessable/loadable/playable
Playing files directly from the Mp3 player or loading them on the hard drive are both do-able and both methods should work.
32helpful
11answers
SD Card not showing in my Tomtom go 720 to play MP3
If you want to play mp3 songs from sd card then create mp3 folder and place all the songs in side that folder. Now when you go to Juke box menu it will scan all the songs and you will be able to play them the way you want..
2answers
SD card in MP3 player
Was the SD card in the MP3 player when you loaded the songs or did you load them some other way?  You may have to first put the SD card in the MP3 player first, then load the songs onto the player.
Top SanDisk Audio Players & Recorders Experts
SmartAviator
SmartAviator
Grand Canyon Tech
Grand Canyon Tech
Alexander
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
