Need to remove Nordictrack 1500 commercial treadmill motor cover. Removed the four phillips screws from front of machine but it still will not come off any ideas?
There are four screws in the front, but also two screws on the bottom. You need to lift the running deck and you will see one screw on either side.There are four screws in the front, but also two screws on the bottom. You need to lift the running deck and you will see one screw on either side.
You can't post conmments that contain an email address.
You have to lift up the back of the treadmill a little to access 2 phillips head screws that keep the motor cover on, (note that you will also have to unscrew a few phillips head screws on the bottom front of the cover as well in order to remove it completely). Before you begin lifting the back of the treadmill platform off the ground to access the screws underneath make sure the treadmill is on a zero incline setting and it helps to find a sturdy object you can rest the tail end off the treadmill on about 1 to 2 feet above the ground giving you enough room to access the screws underneath. Another option is to lift the treadmill platform all the way up and lock it in an upright position using the locking mechanism and lock handle that is located underneath the machine. I find this route to be unnecessary and cumbersome for what you want to do. Once you lift the treadmill up you will see the 2 small Phillips head screws near the front of the treadmill running platform that you need to unscrew in order to take off the motor cover. You also need to unscrew a couple small screws under the machine located on each side of the wood running board. These screw fasten the top inner plastic side covers onto the top of the running platform which needs to be taken off in order to access the back rollers. Make sure you collect the screws in a way that you will remember where they go later when you reassemble as this is your first time taking them out and you might forget later. Now with the bottom screws out, lower the back of the treadmill down level on the ground and pull off the motor cover, and the Left and Right INNER plastic running platform covers. With the inner covers removed you will find yet another small set of screws fasting the main plastic side covers to the running board which require an allen wrench to unscrew. Use the small wrench that came with the machine if you have it handy. With those off you can pull the main Left and Right plastic running board covers off, just make sure to carefully unsnap them from their snap points near the bottom rear of the machine. With all the covers removed you can now access the bolts that hold your treadmill rollers in place and the drive belt which you will have to slip on and off the motors drive pulley and the front roller using a pull and turn technique. The back rollers are simple and can be removed by unscrewing the tension bolts at the back of the treadmill and pulling the roller through and out of the belt. With drive belt set aside and all roller bolts removed you can take out the front roller in the same way you removed the back roller. Replace the treadmill belt and reassemble the machines components in the reverse fashion you disassembled them using these instructions. Doing this yourself will save you hundreds of dollars service man visits in the future.
1 Kneelnext to the left side of the elliptical's base. Use the Phillips screwdriver totighten the two screws located in the center of the left pedal.2 Use theAllen wrench to remove the bolt securing the left pedal arm to the pedal legand body arm. Use the Phillips screwdriver to remove the screw securing therear end of the pedal leg to the crank arm.3 Pull theend of the pedal leg free of the crank arm. Wipe the crank arm clean, thenapply a fresh coating of machine grease or silicone lubricant. Replace the endof the pedal leg back onto the crank arm and use the previously removed screwto secure it back into place.4 Join thefront end of the left pedal arm to the ends of the pedal leg and body arm. Usethe previously removed bolt to connect the pieces together.5 Move to the right side of the elliptical and repeatthe above steps on the right pedal arm
Adjusting the speed sensor:If the calibration does not pass you may need to check the speed sensoralignment.1) Remove the motor cover hood by loosening the 4 screws that hold it inplace (you do not need toremove them completely).2) The speed sensor is located on the left side of the frame, right nextto the front roller pulley (thepulley will have a belt around it that also goes to the motor). Thespeed sensor is small and blackwith a wire connected to it.3) Make sure the sensor is as close as possible to the pulley withouttouching it. You will see a magneton the face of the pulley; make sure the sensor is aligned with themagnet. There is a screw thatholds the sensor in place that needs to be loosened to adjust thesensor. Re-tighten the screw whenfinished.
I just went to a physical therapist who has two NordicTrack treadmills that are down with the exact same problem. The plastic pulley that is on the belt spindle is spun. How you check this is remove the front cover. (four screws in the front, two under the sides) Now, with the cover off start up the treadmill at two miles per hour and walk on the thing, then try to slow the machine down. If this pulley has failed you will see it spin on the belt roller.
I have not yet contacted the company about this design defect, but did read that some people have drilled through the pulley on opposite sides and installed a small screw into the roller (being careful not to drill into the bearings)
I am saddened by this defect. This machine has a lot of innovative designs that are fantastic and great quality in all other respects.
need to flip side and with a wrench 1 / 2 or 9 / 16 loosen the screw of motor base and try to press the down key and if so work you should Lift motor replacement
There are 2 more screws located on the bottom side of the cover. You will need to fold the treadmill down to the ground, console should fold down on top of the walking surface. This will expose 2 holes close to the front roller bottom. These screws are phillips head and need to be removed as well. This will free your cover allowing you to remove it.
How do you remove the motor cover on the nordik track 1000
