SOURCE: Motorola E815 has been paired with VRBT300V Bluetooth
I recently bought a VRBT300V at Costco. I cannot seem to get any volume out of the speaker making it impossible to answer the phone or use im my automobile
SOURCE: Motorola H715 not connecting with my LG Rumor
Do this:
Turn the headset off.
Set your rumor to find new devices, then immediately turn the headset back on. The devices should pair together. If the rumor asks for a code, the code is 0000.
SOURCE: can't get existing bluetooth headset to work with new phone
I had that problem when I changed handsets. You need to:
SOURCE: Kodak Smart touch button not working
I had same problem with Kodak s1220 scanner. Smart button didn't invoke the oem program in Windows 7 64 bit. It started the windows program which wasn't as slick as the oem. I un-installed and re-installed programs in all kinds of orders to no avail. The updates didn't address the issue. I finally started digging in the various folders in the update package and found a directory called "Button app" it had a install setup program and a file called "killKSS". After that it worked! Sweet. Now if I can only charge kodak for my time.
SOURCE: I have a H270 Bluetooth headset. I charged it
I had the same problem. I plugged a USB charger into the headset and turned the power switch off. It worked as normal after that. I think it does not like to be "on" when the USB is disconnected. Anyway it seems the plugging/unplugging kick-started it.
